What would cause so much smoke to coke from the exhaust like this?
Discussion in 'Questions To Truckers From The General Public' started by Nick209, Nov 18, 2022.
  1. Nick209
    Nick209 Bobtail Member
    26
    17
    Nov 4, 2022
    All of the sudden this Peterbilt just started pouring massive amounts of smoke through its exhaust. The driver just put his hazards on and kept going. He didn’t appear to be in any rush to stop the truck, so I’m curious, is this a devastating sight to have in your own truck? It reminds me of when a car finally blows a head gasket, and white smoke comes from the exhaust, but not nearly as much
    https://youtube.com/shorts/ZiXTEG0Rzmo?feature=share
    D.Tibbitt Thanks this.
  3. Cattleman84
    Cattleman84 Road Train Member
    9,946
    70,937
    Nov 1, 2017
    The Sticks, Idaho
    Hes a livestock hauler, he ain't going to just hit the shoulder and call roadside assistance... He probably knows of a place to get safely off the road a short ways up the road where he can fix the problem, which is probably a blown turbo.
  4. D.Tibbitt
    150,570
    Truck just doing a regen
    ducnut, Judge and Cattleman84 Thank this.
  5. Cattleman84
    9,946
    70,937
    Nov 1, 2017
    The Sticks, Idaho
    Lol... That was my first thought too, until I saw the rig.
    ducnut, BennysPennys and D.Tibbitt Thank this.
  6. D.Tibbitt
    150,570
    Still gots a def tank of the side of the truck. Who knows if it just for looks tho.
    BennysPennys and Cattleman84 Thank this.
  7. Cattleman84
    9,946
    70,937
    Nov 1, 2017
    The Sticks, Idaho
    True. We have a few trucks that have DEF tanks that are just for looks.
  8. AModelCat
    160,273
    Just did a blown turbo on a hoe with all that fancy emissions junk on it, smoked heavy white smoke just like that.
  9. D.Tibbitt
    150,570
    I imagine all the emissions junk gets plugged up pretty good from that .. Did you have to replace/clean all of that as well?
    Cattleman84 Thanks this.
  10. AModelCat
    160,273
    In addition to turbos I ended up having to replace the whole emissions box since its a sealed unit. Oil was actually blowing out the exhaust and down the side of the machine.
    Believe it or not it actually idled pretty good for having a turbo with a detached turbine wheel. It had the twins on it so the larger one was probably still doing its whistle stuff lol.
  11. justcarhaulin
    justcarhaulin Light Load Member
    153
    238
    Jul 20, 2015
    My truck (peterbilt 389) does that once in a while after running thru stop and go traffic. Soot accumulates then it's burned off once you are at highway speed hence the white smoke. A warning that shows high exhaust temperature will appear on the dash. Peterbilt recommended we drive under a heavy load to burn off all the soot. That's the price we pay for having the new Def equipped engines.
    The Railsplitter Thanks this.
