What would happen: DOT inspection with a leaking fuel tank
Discussion in 'Trucking Industry Regulations' started by icemerg, Apr 22, 2019.
  1. The Gels
    The Gels Light Load Member
    212
    286
    Apr 13, 2019
    Shreveport, Louisiana
    Oh, yeah, it wouldn't be a big deal I don't think. Heck, the water we used to drink in the military always smelled/tasted like JP8 anyways.
    Grumppy Thanks this.
  3. wis bang
    wis bang Road Train Member
    3,398
    4,007
    Jan 12, 2011
    Levittown, PA
    1 part per million is a measurement often used when dealing with spills, contamination and pollution.
    The enforcement Nazi's can get worse, one part per billion, LOL
    the first inch of 16 miles = 1ppm
    4 drops form a 55 gal drum = 1ppm
    ain't much is it?
  4. Grumppy
    3,092
    10,610
    Dec 11, 2010
    West Monroe, La
    JP8... are you sure you werent drinking out of a fuel line off an F-15 & thought you had a garden hose... LOL
    Yeah, heck, when I was a kid, we'd drink out of a pond or a water hose, or a cow track... whatever we had at our disposal where ever we were.
    Still. to the OP.. you'd still be put OOS with a leaky fuel line.
  5. The Gels
    212
    286
    Apr 13, 2019
    Hah, I think it was because they stored the water jugs and the fuel jugs in the same conex box and JP8 gets everywhere.
  6. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    I found a fuel leak 1 oz per min... put a cup under it and had to dump ot in the tank every 5-6 min... road service showed up and put some Teflon tape on a screw ran the screw thru the pin hole and sealed it... that was 6 years ago and it's still not leaking
    sealevel Thanks this.
  7. wis bang
    3,398
    4,007
    Jan 12, 2011
    Levittown, PA
    emergency responders carry 'plug N dike' to seal smaller leaks along with a bunch of softwood, conical, plugs sized for a bunch of punctures. the also carry a folded up 'kiddie pool' type containment to place under the leaking tank.
    Our local county Haz-Mat team will respond and stop the leak before having the carrier hire a clean-up crew to finish the job. Then they invoice you for the 'expendables' used to control the leak. They have kept stuff out of the storm sewers and actually saved us thousands in the long run,
    BTW the NJ DEP feels anything liquid that hits the street is now waste and MUST be disposed thru a cleanup company; they are slowly becoming the California of the east!
    Ffx95 and 25(2)+2 Thank this.
  8. Ridgeline
    22,418
    116,654
    Why just not get the tank fixed?
    wis bang Thanks this.
  9. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
  10. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    From the CVSA North American Standard Out of Service Criteria manual
    FUEL SYSTEMS
    a. Liquid Fuels
    (1) A fuel system with a dripping leak at any point (including refrigeration or
    heater fuel systems). (396.3(a)(1))
  11. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    I had a leak at valve at bottom of my tank I just fixed. I used a cheap harbor freight transfer pump and 20 percent off coupon and 2 Home Depot trash cans to pump my fuel into and changed out the fittings. Just use broom handle zip ties to suction hose to get all the fuel out. Hope this helps
    12 Volt DC Transfer Pump
