What would you do?
Discussion in 'Questions From New Drivers' started by herkloader1, Apr 21, 2013.
  1. herkloader1
    herkloader1 Light Load Member
    56
    37
    Apr 28, 2011
    Hingham, Montana
    What would you do if you where in the middle of no where and your trailer loaded with fertilizer caught on fire?
    Looking in the mirror it progress from sparks to air loss {120 psi-90 psi then stabilises}and a bright glow in a matter of seconds.It is fairly flay ground
    My boss says you could keep driving and the airflow would put the fire out.
    After some responses I will tell you what I did.
    By the way this was my 16 yr sons first ride, it is one he will never forget.
    P-3
  3. bp88
    bp88 Light Load Member
    149
    48
    Apr 20, 2013
    Orange County, CA
    Well, after seeing what happened to that fertilizer plant in Texas the other week I would stop ASAP and get out. It's not worth risking your son's and your own life.
    Puppage Thanks this.
  4. Scott72
    Scott72 Road Train Member
    2,747
    1,758
    Apr 7, 2013
    Worst advice in history. When I was a deputy we had three people burned alive from a fire in the back of their pickup. They also thought if they drove fast enough it would put the fire out.
  5. Ridgeline
    22,385
    116,218
    I would tell him to demonstrate his idea and then see if he survives but nevertheless I would quit, he isn't a boss I would like to work for.
  6. bp88
    149
    48
    Apr 20, 2013
    Orange County, CA
    Yeah, that usually just feeds the fire even more. Fire thrives on air. I'd definitely have a talk with your boss about the incident. His advice could have seriously hurt or killed you and your son. My boss gets careless when our truck needs service. It has BAD oil leaks, SIX inches of play in the steering wheel, and a few other issues but he still procrastinates when it comes to taking it in for service. I should probably refuse to drive the truck because it only gets worse. So, even though they may be in a management position - they may not always be thinking of what's right - they just want to see dollar signs.
  7. Six9GS
    Six9GS Road Train Member
    1,473
    3,695
    Dec 3, 2012
    Yuma, AZ
    My common sense would say to stop as far off the side of the road as is safe and if I think I can, unhook from trailer to try and save the truck, especially if it was my truck, if it was a company truck, don't think I'd risk much to try and save it too. Trucks and trailers can be replaced. What ended up happening?
    btw, to continue to drive to so the airflow would put the fire out is kind of like adding gasoline to a fire thinking it will put the fire out to my thinking and understanding of basic chemistry.
    RickG Thanks this.
  8. snowwy
    snowwy Road Train Member
    20,545
    13,280
    Jul 6, 2009
    i had a load of hay catch fire. after i got unloaded there was a cigarette butt in one bale. you could see the hole. and it wasn't MY butt.
    i just stopped and pulled out the fire extinguisher. someone else called the fire department though. to which the fire was out by the time police showed up. let alone the fire engine.
    showed the receiver and they said not the first time they've received a burnt load. the actual amount burnt was so small.
  9. shriner75
    shriner75 Heavy Load Member
    849
    575
    Dec 7, 2008
    Minnesota, dontcha know...
    Loaded with fertilizer? Either its liquid or dry bulk. Either one wouldnt catch fire on their own. So you must have had the trailer brakes engaged? Anyways...I'd just stop and check the trailer with a fire extinguisher in hand....
  10. herkloader1
    56
    37
    Apr 28, 2011
    Hingham, Montana
    Here is what happened.
    I was almost home when this happened. I live 40 miles from a town with any size.
    I had my 16 yr old son with me enjoying his first time in a big truck. He was wiped out so he was in the bunk.
    I noticed a very quick drop on air pressure for no reason. It dropped from 120-90 and then stopped. I was trying to figure it out and find a spot to pull over,
    As I did a mirror check I thought I saw sparks coming from my rear axle area. Then no sparks. I thought hey I must be tired I am glad I am almost home.
    Air staying steady and no more sparks.
    Then before I could get stopped lots of sparks out the left side and a nice glow coming from both sides.
    As I was getting stopped I woke my son up and told him we had a small problem. I told him I wanted him to put my ANSI reflective jacket on , grab one of my flashlights and make sure he had his phone. I told him as soon as we got stopped he was to exit his side and go well forward of the truck and call 911 while I tried to get the fire out. Note the fertilizer while dangerous was not as bad as some it was 11-52-0.
    He went forward and called 911.
    I grabbed my fire extinguisher and assessed what was on fire as I moved aft.
    It looked like the right wheel area was on fire.
    I thought about tires exploding from the heat and stopped for a few seconds before deciding to continue. In order to hit the fire right I choose to leave the hose in its clip and slide the extinguisher behind the tires so it would point back at the fire.
    I hit it and the fire went out. I was just thinking cool when it started again. This happened three times. The last time it came back with a vengeance.
    I quickly went back to the front of the truck on the left side. As I passed the gear a tire blew and scared the snoot out of me. It also scared my son as he came running back to make sure I was alright. I said yes and sent him back away. The
    ire that blew blew the wheel hub and bearings out, Had I not moved it would have blown through me.
    I made the decision dispute the heat to try to save the tractor. I hit the air release on the trailer on the way by and dropped the landing gear and pulled the fifth wheel release. I was amazed that I was able to reach and release all the airlines and electric with one hand so I did not have to go up on the cat walk. I got my tractor away as the fire was getting big enough that the flames where over twenty feet above the trailer.
    I crossed a hwy and got upwind off the fire and waited about 10 mins for the VFD to show up. They show up with a brush truck as the dispatcher told them it was a pick up truck trailer fire. To their credit they got the fire out with what amounts to a fire hose. They did have to go back and refill the truck once though.
    While the trailer appears to be a total loss all but a few hundred pounds of product was saved.
    I am not afraid to say that I learned several lessons from this. I am most thankful that my son is alright and that he did not get hurt, I am very proud of how calm he was and that he did everything that was asked of him.
    I had been told in the past by several folks to keep going. That is how we would put out a wing fire,nut that is much higher speeds and thinner air. I was not willing to do that in a truck.
    I did however stop it at a stop sign where folks are used to stopping so no one would run into the back. I also made sure I was well on the road so as not to catch the dry fields on fire.
    It all happened so quick I am glad it turned out as well as it did.
    I know all the tires etc where good at least visually since 90 miles before when we stopped for fuel he asked me what I was doing so I let him do it all while I watched and explained it to him.He thumped all the tires,check the fluid levels in the bearing and checked all the lights. as well as the air levels in the trailer and the airline connections for leaks.
    So anyways I have a thick skin after flying for 30 years so go ahead and tell me what would you have done?
    Big Don, Pound Puppy and BlueSparrow Thank this.
  11. bp88
    149
    48
    Apr 20, 2013
    Orange County, CA
    Seems like you did what you had to do. You two are uninjured. I would've probably freaked out way more than you did even without a kid in the truck.
