What's in your toolbox - Besides tools?
Discussion in 'Experienced Truckers' Advice' started by brian997, Aug 21, 2011.
  1. brian997
    brian997 Bobtail Member
    15
    13
    Jul 20, 2011
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    I keep my girlfriend in there.
    shriner75 Thanks this.
  4. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    I saw one driver had a bottle of whiskey.
  5. Lonesome
    Lonesome Mr. Sarcasm
    11,462
    23,682
    Dec 15, 2007
    Northern Indiana
    Wire ties, the drivers best friend.....
  6. lobes1985
    lobes1985 Medium Load Member
    306
    112
    Aug 9, 2009
    Wappingers Falls, NY
    I keep atleast one air to air boot, extra radiator hoses, hose clamps, a gallon or two of coolant.
    Almost forgot one, waterless hand cleaner. When you have to work on your truck on the side of the road it's always nice to clean up before getting back in the truck
  7. seabring
    seabring Road Train Member
    1,844
    1,882
    Apr 24, 2011
    A couple of fuel filters , a filter wrench , oil filters, drive belts, radiator hoses and hose clamps,radiator coolant, engine oil,power steering fluid, washer fluid, a couple of tubes of grease for the fifth wheel, air line antifreeze in winter, a spare windshield wiper blade or two, spare fuses , globes and a little electrical connection kit, de-mineralized water for your battery ( a jar of vaseline is good to keep to coat your battery terminals with to keep away corrosion) ,WD40 for squirting your pig tail, a good big roll of shop towel and GO-JO orange hand cleaner. Sounds like a lot but when you need this stuff your glad you have it.
  8. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Stuff like that, I'd keep in the sidebox. Fuel filters, oil filters, extra glad hand seals, fuel/oil filter wrenches, oversize flags/banners, pipe stays (I didn't haul pipe that often, so the stays could be kept in the sidebox).
  9. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    I carry fuel filters, lights, coolant, motor oil, gear oil, clamps, glad hand seals, an oil hub, zip ties, tape, electrical wire and connectors, penetrating oil and some other things i can not think of at the moment. Basicaly anything i might need to keep the truck going in a pinch.
  10. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    I'm local so I don't keep all the spare fluids and parts, I keep a small amount of hand tools, 7 chains, 7 binders, 3 hand straps, 1 can of pb blaster, 1 winch bar, 1 large crow bar, 1 3lb sledge hammer, 1 homemade arm extension ( i took a 4 foot piece of all-thread from the scrap pile and bent about 110 degree bend on the end to make kind of a hook, i use it to pull chains through tight places) and some spare gloves and hand cleaner.
  11. the gambler
    the gambler Medium Load Member
    330
    245
    Feb 14, 2011
    Kentucky
    Duct tape and a pop can, quick repair for turbo hoses
