Whats the best way to Berryville/AR from Jackson/MS
Discussion in 'Questions To Truckers From The General Public' started by hendrix69, Jun 7, 2025.
  1. hendrix69
    hendrix69 Bobtail Member
    37
    7
    Jun 4, 2025
    Hi guys. it’s gonna be first time i will drive 80klbs with a reefer load from jackson ms to berryville AR. I heard that AR mountain roads are too bad. Please any advice? Thank you.
  3. Big Road Skateboard
    6,436
    36,018
    May 2, 2021
    You can go either that way, or over to Clarksville and up 21, or up 7 out of Russellville.
    I think out of Conway, the way you have on your map, would be safest for ya. I use the other two routes more just because of where I run out of most, but they might be a bit much for ya.
    hendrix69 Thanks this.
  4. hendrix69
    37
    7
    Jun 4, 2025
    Which road has the least slope?Which road would be most appropriate to use in a way that would put the least strain on the engine?65,7,21?
  5. kemosabi49
    10,784
    46,487
    Jan 13, 2013
    SW Arkansas
    i would run 62 to65 down to Conway. Then I 40, then I 30 through Little Rock. I 530/65 though Pine Bluff all the way down to I 20E at Tallulah, La over to Jackson. Sure, there are down hills but just take it easy and you'll be fine. No way to avoid hills from Berryville.
    Note: if you are placarded/Hazmat, you can't run I 30 through Downtown in Little Rock.
  6. hendrix69
    37
    7
    Jun 4, 2025
    Yeah i think i am gonna use that way today.
