What's the deal on idling?
Discussion in 'Questions From New Drivers' started by SOTEX, Apr 6, 2012.
  1. SOTEX
    SOTEX Bobtail Member
    If it is not ok to idle the truck for cool and warmth, how do drivers manage to get a good nights sleep, especially when it real hot or cold outside the cab?:biggrin_255:
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    With fuel over $4 a gallon, companies are doing everything possible to save money.
    It all depends on the company. Some let you idle, some don't. Some use the ECM to control your idle. Some have APU's and bunk heaters. Some use IdleAire.
    It's something to consider when job hunting. Personally once spoiled, I wouldn't work for a company without an APU. You have to stay comfortable if you are going to live in that box. Students might not have much choice. But when you get experience you call the shots.
    Then there are a few states with strict idling laws. APU is the way to go.
    Everett and anj8488 Thank this.
  4. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    Do your trucks not have night heaters or cab cooler units?
  5. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Most of the larger companies who do not offer APU's, will allow their engines to idle when outside temperature is above around 75 degrees. And it seems most have bunk heaters that work well in wintertime. They B##ch and gripe when idle time is excessive but to not take into account the driver spent 70% of his time in a given period in the South and Southwest. Walk away from a company who does not have a reasonable idle policy and refuses to provide APU's. They will eventually have to adjust their thinking or will add APU or have truck's sit driverless.
    Sleeping in a truck in Phoenix in August without A/C? ... no way
  6. ewill71
    ewill71 Heavy Load Member
    759
    234
    Oct 3, 2011
    mcgregor tx
    i think if it was a great idea for idleAire. I cost a couple bucks per hour but you get all the quirks with it.
  7. Allow Me.
    10,676
    12,223
    May 28, 2009
    Rancho Mirage, Ca.
    Our trucks have heaters and AC which requires the engine to be running obviously. However, a lot of localities forbid idling now-a-days because of exhaust pollution etc. Plus the cost of diesel fuel and truck companies are crying big tears. So, hence APU's (auxiliary power unit) have come into play in recent years which allows you to run the heat/AC without the truck engine running. But the APU is expensive (new, $10k) and it is also a small engine in itself that uses fuel, but a lot less. But not every truck company has APU's.
  8. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    I've had a APU the past year and refuse to work for a company that has a idle policy and doesn't provide a alternative.
    May trucking was the strictest company I worked for regarding idling but heard they increased their threshold significantly.
    U.S. Xpress didn't care about it when I worked their (07-09) as long as it was shut off when you weren't in the truck ( I have heard that changed)
    Total Transportation didn't care either.
    I have a APU at my current company and they are going to equip all new trucks with them.
  9. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I think we've all been there. After running across a 110 degree desert with your windows down waiting for darkness so you can sleep or being down in humid Florida with sweat balls popping off you and mosquito's the size of a buzzard biting you.... one kind of figures out a better idea! :)
    anj8488 Thanks this.
  10. SOTEX
    Thanks for the informative respones.:biggrin_25514:
  11. Jorihe84
    2,763
    1,333
    Sep 1, 2010
    North Florida
    The issue I had with idle air was being a non smoker and having a plume of nicotine go into my cab when I turned the a/c on.
    Never again.
    Roadmedic Thanks this.
