What's the speed limit for a 26 straight truck in California ?
Discussion in 'Questions From New Drivers' started by EZ-VVV, Apr 27, 2012.
  1. EZ-VVV
    EZ-VVV Bobtail Member
    6
    Sep 27, 2011
    Los Angeles
    I know that truck shouldn't go over 55mph in Cali,
    but does it counts the class C trucks too ?
    (I have a class A but tomorrow need to drive a class C straight truck...)
    Thanks
  3. Truck Driver
    Truck Driver Medium Load Member
    330
    136
    Dec 5, 2007
    Sacramento, CA
    It depends, as I understand it, on how many axles you have on the ground. A two axle straight truck, with no trailer, should be legal for whatever the higher posted limit is be it 65 or whatever. A three axle straight truck is limited to 55 unless he lifts one of those axles off the road. It don't matter how long your truck is. Even cars pulling a little U-Haul trailer are limited to 55. Three axle Busses are exempt.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
  5. Allow Me.
    10,687
    12,271
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah, in Ca. it's axles that determine it. A single screw bobtail/straight truck can do the speed limit and any lane, just like the 4 wheelers. A twin screw bobtail/straight truck is slow lane and 55 max. Busses are exempt.
    CondoCruiser Thanks this.
  6. SoCalDave63
    SoCalDave63 Bobtail Member
    16
    8
    Jun 12, 2011
    riverside, ca
    In the los angeles area seen a 3 axle tractor bobtailing in the # 2 lane of 4 lanes. Told him on the cb big ticket in that lane, replied it's legal to bobtail in that lane, call cal dot. I did and to my sunrise it is legal. But forgot to ask about speed limit
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    California likes to make things complicated.
    LaBubba Thanks this.
  8. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    Unless the bus is pulling a trailer, then it's 55.
  9. Allow Me.
    10,687
    12,271
    May 28, 2009
    Rancho Mirage, Ca.
  10. Scuby
    Scuby Heavy Load Member
    816
    235
    Mar 10, 2007
    SoCalBob usually when there 4 or more lanes in Calif. the right 2 are legal for T/T. If you look at the overpasses sometimes you'll see a sign that says trucks ok and this means its legal for T/T's to be there. EZ-VVV its any Commerical truck over 10k is limited to 55. In reality CHP tends to leave a truck alone at 60mph as long as they are not doing something stupid. I've seen CHP pass trucks doing 65 and do nothing in the rural areas of Cali,once again as long as they aren't dong anything stupid. This also comes down to the individual CHP officer as well. Most are ok,but you might get that is in a bad mood for whatever reason and decides to get picky.
  11. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Was told by chp at the cottonwood scales on I5 that bobtails can do 70 even with 3 axles.
