What's the worst damage you have seen to a drivetrain?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jbrow327, Nov 26, 2021.
  1. Jbrow327
    Jbrow327 Light Load Member
    141
    83
    Sep 28, 2019
  3. AModelCat
    161,208
    Clutch was shot. Discs were warped about 3" each and intermediate plate was cracked. Cause was stupidity.
    Another time I found some chewed up snap rings on the magnets when I had a PTO off. Boss said send it. Slapped repaired PTO back on. Backed it out the door and it was sticking in gear. Told boss the transmission needs to come out. Boss put it to work. 2 hours later the lower countershaft decided to eject itself through the case and onto the highway.
    D.Tibbitt, bzinger, prostartom and 2 others Thank this.
  4. xsetra
    xsetra Road Train Member
    5,144
    7,058
    Aug 21, 2011
    Twin screw: Inter axle driveshaft forward u-joint came apart. Driveshaft jammed into roadway took out rear axle housing. Busting rear u-joint the shaft then totaled the car following to close to react.
    Single axle: had a u-joint replaced. Shop didn't grease the joint. 1,500 miles later pulling an oversize load. The u-joint came apart, damaged transmission, rush hour in the twin cities I694. Blocking right shoulder and slow lane of traffic.
    ibcalm19, D.Tibbitt, bzinger and 3 others Thank this.
  5. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I've seen a driveshaft twisted into two pieces. More recently, the input shaft bearing on my 13spd decided it didn't want to be part of the family anymore.
    bzinger and Pamela1990 Thank this.
  6. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    This doofus is your boss?
    Craptastic boss.
    prostartom Thanks this.
  7. Pamela1990
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    Watched a super trucker try to start from a complete stop, on a minor hill, twist the driveshaft like a pretzel in a Peterbilt.
    Before you ask, he was caucasian, fat, wore jeans, and boots.
  8. 201
    201 Road Train Member
    12,567
    25,747
    Apr 16, 2014
    high plains colorado
    Guy I used to work with used to be a asst. manager at a truck repair. Guy comes in, says an awful shaking,,,"bring 'er in", he said. Crawls under, the driveshaft was "cork screwed" like a drill bit. How it moved at all was the miracle.
    Another one, when I worked at the asphalt company, had all Macks, guy stops on the scale loaded, gets his ticket, puts in 1st nothing, reverse, nothing. They towed the truck, turns out, the crankshaft broke right before the flywheel. Engaging a power divider while spinning always creates work for the garage,,,
    Pamela1990, bzinger, AModelCat and 2 others Thank this.
  9. Big Road Skateboard
    6,553
    36,765
    May 2, 2021
    5 or 6 years ago got a service call to one of the local LTL Carriers. Line haul truck coming out of the gate, foot slipped off the clutch. All three sections of driveshaft were on the ground, front held only by the carrier bearing.
    Last year a customers 18 in Texas. Driver pulled up to a stop light. Eased out on the clutch and the stick went through the floor. Tranny had got into two gears at once. Usually that just twists the mainshaft and kills the engine. Never seen it before, but this transmission broke the flywheel housing off of the back of the engine, and spun the trans 3 or 4 times before he got it shut off.
    Tearing up all kinds of stuff in the process.
  10. AModelCat
    161,208
    This was over a decade ago and my foot was already out the door at that point. They had about 700 units total and went bankrupt shortly after I left.
    Ironically enough I moved halfway across the province last year and the company next door to where I work owns about 30 of their old trucks.
    Pamela1990, Isafarmboy and D.Tibbitt Thank this.
  11. Opus
    126,851
    My latest adventure.......it cost the original 'repair' facility right at $11,000. Just got the check yesterday.
