What's with all the gears ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by *Coyote*, Jul 27, 2014.
  1. *Coyote*
    *Coyote* Bobtail Member
    49
    19
    Jul 18, 2014
    Louisville, KY
    Ok, so I realize I'm still a newb, but I've asked friends that drive and the only answer I can get is "different gears for different things". Can somebody please explain to me why there are 9, 10, 11, 13, 15, 18, gear set ups? I know most of the big fleets stick with a 10. But why so many options? Does it have to do with what your hauling or rear end setup, what? So anyways, thanks for any input/explanation on this.
    And for the record, I did a search and couldn't find an answer. But may have not been searching the right term in my defense.
    Coyote
  3. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    10 speeds are the most common with fleets because they are tough transmissions they get the job done and they are easier to teach rookies how to drive them without doing damage to the trans.
    the more gears the closer your rpms between each gear to allow you to run the engine more optimally, witch is especially important when over 80k but even usefully at lighter weights, 18's are basically a stronger 13 that allows you to split the bottom side as well as the top witch is most use full in trucks that are used for real heavy haul or that spend time off road.
    15 is basicly a cross between a 10 speed and a 18, 10 speed pattern that allows half gears on the bottom side. usefull for getting heavy loads rolling or offroad
    9 speed is essentially a 10 speed but with a 13-18 speed shift pattern without any 1/2 gears.
    13 is a 9 speed that has 1/2 gears on the topside of the box
    kw9's rock, *Coyote* and wore out Thank this.
  4. *Coyote*
    49
    19
    Jul 18, 2014
    Louisville, KY
    So essentially it's all about fuel economy and more low end torque? Does rear end gear ratio come into play at all with transmission selection?
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    its all a package deal what engine your running with what trans with rear ends to match for the type of freight your hauling.
    a guy running permitted loads at 180k gross is going to spec a truck a lot different than a guy hauling auto parts in a dry van at 65k gross.
    the whole drive train works as a package what is optimum for one application wont be for another but everything works together to achieve what you want what motor coupled with what trans and what rear ends.
    in my opinion you can never have too many gears in your trans, you don't have to use them all if you don't need them but you have them available if you do. but a 13 or a 18 can be a bit much for a new driver to get the hang of, so if you had a truck that you were going to put new drivers in you would probably choose a 9-10 speed for ease of use and less transmission repairs resulting from driver error
    *Coyote* and kw9's rock Thank this.
  6. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    nice thing about the 18 speed is you can leave it in OD and run it like a 9.
    i hate 10 speeds. i like the 9 speed platform.
  7. Cat sdp
    Cat sdp . .
    20,968
    73,033
    Apr 8, 2012
    Orion's Belt
    Plus the 10 speeds aren't rated for 550/600hp with 1850/2050 lbs of torque. You need a 13 or 18 speed.......
    Also with a heavy load and high hp it's nice to split a gear and go. A lot of times this will put you over the top of the hill. After a while you just know when to split and when to drop a full gear......
    Lucar and *Coyote* Thank this.
  8. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    If you're doing anything in off-highway conditions, 18 speed is the way to go. For a highway truck, it can allow you lower rear end gear ratios and additional gears on the low side to compensate.
  9. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    There is only one thing worse then a 10 speed and that is a super 10. If any one has operated one of these I'm sure they will share the same opinion. Had a super 10 in the flat top freight when I was running flatbed. The Detroit 60 worked great but so many times I wished for more gears. I have always been a 13 speed fan always thought they were stronger then a 18 but could be wrong.
  10. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    All motors have a sweet spot on the RPM range. The closer you keep it to that spot, the more power and mpg you get. In a 10 speed truck you may need to drop 400-500 rpms on each shift since the gaps between gears is pretty big. On a 13 0r 18, the gaps are smaller thus you can stay closer to the peek rpm. On real heavy or hilly conditions the extra gears help since the rpm drop will be ore under these conditions. On flat driving with not real heavy loads a 10 is just fine.
    9 and 10s are similar except a dfferent shift patern. A 13 is a 9 that has splitable top gears. (half gears) A 18 is a 9 with all gears splitable.
  11. postmandav
    postmandav Medium Load Member
    313
    90
    May 18, 2008
    south portland, maine
    Just because you can split the gears, you do not have to (I think). Could you teach someone to drive an 18 speed but drive it as a 9 speed? As they get more comfortable then they would start splitting the top end. since you are not splitting, would that cause any damage to the tranny?
