Is it normal when you loose a drive axle wheel bearing to result in break of the half axle.First I saw the smoke from the brake shoe. When I stopped i saw the shoes are protruding half inch from the drum, which told me that I have lost the bearing. Then I tried to pull the half axle I found it broken two inches from the flange. I didn't expect that the small change of the angle, that happen because of the failed bearing,which I found in pieces, would lead to breakage of the half axle. Has anybody heard of anything like that?
wheel bearing failure leads to broken halfaxle
Discussion in 'Volvo Forum' started by trikefloats, Jan 4, 2012.
