Wheel bearing
Discussion in 'Volvo Forum' started by Frank5229, Oct 20, 2012.
  1. Frank5229
    Frank5229 Light Load Member
    50
    Mar 20, 2012
    Calgary
    I have a 2001 volvo d12c , serial 317328
    Does anyone know the torque on the wheel bearing?
    Also the tightening procedure?
    my local dealer won't give me that info.
    thanks
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Normally I put the hub on fill with gear oil I tighten rhe nut to 250ft spin hub 360 loosen but tighten to 150ft spin 360 loosen nut then tighten nut until you have slight drag and lock it down with the retaininf lock.if you have the style with the center spaced then I belive it is 250ft pounds you can go on to the timkin heavy duty website and check it out as well
    Frank5229 Thanks this.
  4. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    It depends on what type of bearing you have.
  5. Frank5229
    50
    Mar 20, 2012
    Calgary
    I'm using timken bearing
  6. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    A standard bearing set that doesnt have a spacer between the bearings is
    Torue to 100ft. lbs while rotating tire. Back off one full turn. Torque to 50 ft.lbs. Back of 1/3 turn. Locknuts are usually around 200-300ft-lbs. Dont forget to bend lock tab. Final end play is .001-.005"
