wheel centering tools
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Aug 18, 2013.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    does anybody have a link to the wheel centering kit for trucks???? it is the ones that you put on the studs and then mount the wheels so that they are centered...I had it but can not find it anywhere.. also does anybody here have any good bad to say about them?????
  3. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    http://www.nytechsupply.com/tru-balance-centering-products.htm
    I just went to my local truck parts store and bought 4 of the regular self-centering wheel nuts. When I put a wheel on I will start with those 4 and gradually snug them up to center the wheel, then install the rest of the customers regular nuts, then take my centering nuts off and install the rest of the customers regular nuts. Done, wheel is centered. This only works with the steer wheels though.
    beltrans Thanks this.
  4. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Do those self-centering nuts work on duals(rear) wheels?
  5. maxicruise
    maxicruise Light Load Member
    58
    19
    Aug 11, 2010
    Illinois
    They make 3" ones for the steers and 4" for the drives, if you buy the 4" ones you can use them in both places.
  6. Heavyd
    7,752
    6,185
    Feb 4, 2009
    The self centering nuts would only center the outer wheel, not the inner one. The inner shoulder of those nuts have a small cone that sits inside the hole of wheel about 3/16 of an inch or so. To truly center duals you would need those sleeve tools. I should get some, but I run into off centered drive wheels only once in a blue moon. 95% of the time it is the steers I have to deal with. The self centered wheel nuts were only about $6.50 each, I bought four of them, which is only a fraction of the tool set cost. Good place to start.
  7. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    Tru balance centering pins work excellent
  8. granhawler
    granhawler Light Load Member
    296
    56
    Feb 26, 2011
    The local truck parts store has self centering nuts long enough to do both the inner and out wheels on a dual wheel set up so they are available.
    Heavyd Thanks this.
  9. Heavyd
    7,752
    6,185
    Feb 4, 2009
    Thanks, I haven't seen those yet, I will keep and eye out!
  10. granhawler
    296
    56
    Feb 26, 2011
    I tried to find some pics and info of them on the net but had no success but I know for a fact the local parts store (wheelco) has them in different lengths for trucks with steel wheels on the inside & aluminum on the outside & for trucks with aluminum wheels inside and out. I have to go to the parts store tomorrow so I will get the manufacturer & part #'s for them.
    cetanediesel Thanks this.
  11. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Tagged for the info.
