Wheelbase needed to add sleeper to daycab 379/359
Discussion in 'Peterbilt Forum' started by davenjeip, Jul 2, 2014.
  1. davenjeip
    davenjeip Medium Load Member
    459
    257
    Dec 20, 2009
    Port Charlotte, Fl
    If you were to take a daycab version of a 379 or 359 and decide to add a factory sleeper to the back of it, what would be the shortest wheelbase you could do it with? More curious about a 48" flat top, but interested in all standard sizes.
    Not something I plan on doing in the near future (or most likely ever), but I have a million ideas running through my head trying to think about getting back behind the wheel. One of the many thoughts involves running a daycab locally, but having a way to convert that truck to run OTR or regional should all the local freight dry up.
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    I would "guess" somewhere around a 190" with a 48" is going to get the front tandem pretty close to the back of the sleeper, I guess if you have a 132 BBC, and add a 48" sleeper,(about 50" overall with seal) that puts you at 182, subtract appox. 40" from your front axle to bumper and if your tandems are on a 60" spread take half of that for wheelbase, plus half the diameter of your front tandem tire forward of axe centerline.
    So 132" BBC
    -40" ft axle set back
    =92" center front axle to BBC
    +50" sleeper
    =142" center front axle to back of sleeper
    + 50" from front of front rear axle tire to center of tandems (assuming a 60" spread tandem) and a 40" tire.
    So roughly 192" WB and that leaves no room for a deck plate step.
    davenjeip Thanks this.
  4. bad-luck
    bad-luck Road Train Member
    3,376
    6,249
    Nov 16, 2013
    Baltimore, Maryland
    I think 210 inches might be better you will have a little more room you don't want the trailer hitting the back of the bunk
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    As bad luck said 210" would be a good number for a 48 " bunk 244" is good with the 63" bunk.
  6. KANSAS TRANSIT
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
    Agreed, but he asked for the "shortest" so that's what I gave him.
  7. davenjeip
    459
    257
    Dec 20, 2009
    Port Charlotte, Fl
    Thanks. That is exactly what I am looking for.
    It's all about an idea I'm trying to think through, where honestly I am about 20 steps ahead of myself even thinking about what truck would work for my situation. But, I felt like playing around on Truck Paper dreaming about what I would like to have, should my idea turn into something real.
    In planning for success you also have to have a plan in place in case you fail. Dealt with this in a previous business I had, and ended up having to shut it down because I was unable to adapt when the economy went bad and made my business model obsolete.
    Daycab would be best and cheapest for what I am thinking of, but I couldn't get away from the "what if?" scenario. None of that involves any ideal circumstances, or cares what is better, only what is possible as a last resort in a situation where I had no work. Just wanted to know if some of these trucks that I was looking at, while otherwise ideal, would provide any sort of platform where it was possible to do this.
