I have a question regarding how different length wheelbases affect the handling of a truck. Generally speaking, will a longer wheelbase allow you to go faster or slower around curves? Does length help with stability/tippiness?
What is the effect of sleeper size/height on handling? Im assuming those really tall skyrise sleepers make for a top heavy/tippy truck that will like to lean hard in curves?
Thanks in advance to anyone who can help me with this.![]()
Wheelbase
Discussion in 'Experienced Truckers' Advice' started by dieselpowerrules, May 10, 2011.
There is some increased stability, but don't think it means you can whip around curves. If a short wheelbase truck has to slow down for them, so do you. They also turn slower, and require more space to execute a turn in. And don't forget that the stability and handling of the vehicle is also going to be affected by the load.
As for the tall sleepers, they don't make the truck top heavy. The sleeper berth is pretty much fiberglass, or very thin and lightweight metal (depending on the manufacturer, model, etc).. the bulk of the truck's weight is still low centered. They are, however, good at catching wind if you're getting it from the side.Last edited: May 10, 2011
dieselpowerrules Thanks this. -
I understand the speed limit in curves and would never push my luck, I was just curious as to what would handle better. It seems with four wheeled vehicles, the shorter they are in length the better they handle/take corners etc, so I was just wondering if this applies to tractor trailers as well.
Obviously the height of vehicles affects the handling, but wasn't exactly sure as to the affect of length... -
A longer wheelbase is more stable in poor weather conditions...
Condos blow around in a crosswind a lot more than a flat top...
The suspension style makes a big difference in how a truck handles... I believe Peterbilt offers around 13 different configurations depending on the truck and type of operation...Last edited: May 14, 2011
I always found a longer wheelbase made for a smoother ride too.
They are more stable in bad weather for sure. -
I can only imagine a fullsize Volvo, I drove a daycab 2006 something or other (not clear on their models) and even without the front air ride that sucker caught wind real bad compared to the Mack CH I last drove. Them high rise Volvos must really scare the crap outta people that aren't used to them!
What ticked me off was Volvo gave me a free hat, took my photo and posted it on their website and said I like their POS much better than the Pete I owned... should have sued 'em.hup Thanks this. -
I have turned down jobs because they had only Volvos in the fleet.
My International is ok but i would even take an older Freightliner Classic XL over it any day. -
Short wheelbase trucks are more maneuverable in tight places, but every time you drive on a rough section of road you feel like you ought to get another buckle....
Long wheelbase = Ride and Glide!
