I see some of freightliner Cascadia longer from other cascadia I mean from the end of cab sleeper to the end of tractor frame
Don't know what they call that ..
What sizes freightliner made what right one when you pulling 53 trailer is that can make different mpg ?![]()
Wheelbase
Discussion in 'Ask An Owner Operator' started by JORTRUCK, May 24, 2017.
Page 1 of 3
They are called cab fairings. The older model Cascadia's have the narrower cab fairings like 08-12 models, and the wider fairings from 13 to now. I don t understand your last sentence, but if you re asking about fuel mileage, the Evolution model pictured above is supposed to be the most fuel efficient one
Actually, the new redesigned 18 Cascsdia is the most fuel efficient, provided it has the full aero package.
I think I'm talking about the tractor fram some of Cascadia has long frame ?
The distance between the steer axle and the center between the drive axles? That's the wheelbase. I'm not sure how that affects MPG, but your MPG will decrease if you have a larger gap between the back of the truck body and the front of the trailer.
That is something that is specced by the buyer for their needs.
wheelbase you right .. don't no how they count it . Like you said steer axle to the center rear axle .. they count it by feet or meter or inch ?
They count it by inches in the US.
What best wheelbase size to pull 53F
Reefer ? -
163 inch cabover
BeN DaViS, Cottonmouth85, blairandgretchen and 6 others Thank this.
Page 1 of 3
