when do you replace your belts?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MNdriver, Jul 4, 2013.
  1. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
  3. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Ive always done it yearly. Is it overkill?? Probably, however I can go to the local parts house and get the belts PLUS tensioner for just a tad more then what 1 belt would cost me on the road.
    snowblind, MJ1657 and blanco Thank this.
  4. MNdriver
    7,985
    4,372
    Feb 24, 2012
    I don't like setting belt tension without a tension gage. My engine has auto-tensioners on it. My reefer doesn't and I am looking to get a tension gage to put a new set of belts on it here this month.
  5. losttrucker
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Ahh ok now I understand!! I forgit you switched to reefer!!
  6. MNdriver
    7,985
    4,372
    Feb 24, 2012
    I just thought that the "wear gage" was a nice little thing to share with others. Especially since it's free.
    I'm also for saving money and getting full life out of service components too. So If I can extend the use interval even on my serpentine's, I am all for that too.
    Lord knows we pump enough money into these trucks as it is.
  7. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    deleted......
  8. mtoo
    mtoo Road Train Member
    1,936
    4,514
    Jan 15, 2011
    Retired on bended knee
    the alt belt every year and the wider belts that run the fan clutch every 2 years. I would do them all every year, but the ones from the crank to the fan clutch are a real pain to do.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    on some trucks broken belt may be expencive. for example some fan clutches are of visco type ore electrical with PWM control (Volvo, Mercedes, MAN-Navystar), so broken belt easyly damage fan clutch wiring and you have to change fan clutch ($$$$$), it is not all, on MAN engines no fan PWM control circuit protection and short fan clutch wires are the cause of ECM internal damage ($$$$)
  10. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    When do I change my belt? When it doesn't hold my pants up anymore!:biggrin_2559:
  11. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,046
    May 13, 2011
    Middle Tennessee
    I always have a fresh set under the bunk for the alt/ac/fan and crank/fan so my v-belts can go for long time.
