When ice has you stuck on small grades...
Discussion in 'Questions From New Drivers' started by l84work, Jan 20, 2009.
  1. l84work
    l84work Bobtail Member
    47
    13
    Aug 2, 2008
    Pittsburgh, PA
    A couple days ago I was having a hell of a time getting over a slight grade (lets say about 20 yards). I was fortunate and not so fortunate that no one was on the road, as a matter of fact there was (possibly) no one for miles. I was able to back and get a little momentum.....unsuccessful. I tried to take it slow and easy.....no luck. I used the differential....nothing happening there either. There was no way to turn around so there I was making two paths for right and left tires and putting kitty litter in them. After about an hour ....I think I can, I think I can, I think I can.......I was over the grade. I'm looking to hear from others for other ways that I can put in my tool box for future reference. I did say no one was around.....During the whole ordeal not one car or anything could be seen or heard.
  3. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I've been there. I don't know if you've ever been out west but I was heading south on US95 in Nevada pulling triples. In the small town of Goldfield right when you leave town there's a very sharp turn (I'd say 90°) then a small hill about a half mile long. I came through there on the way home and you can't go fast around that turn. So I took it easy around the turn and applied the power the best I could to get the momentum I needed. I only had a single screw tractor and really should have put chains on but I thought I was out of the ice. I did lock the differential and I got to the top but had about 20 feet to go. I just kept a slow spin without alot of torque and let the tires melt the ice away.
    I know it's a bad feeling when you only have a few feet to go but what the heck. You can carry a 50lb bag of sand but how many times do you think you'll be in that situation again? I was coming out of Tonopah on a turn from Las Vegas and there's only that small grade going south. The snow and ice was on top of the grades but not on the bottom so I didn't bother with chains. Nevada is pretty lenient on chains until you have a problem then they take action. Of course if the sign is up you've got to chain up but there were no signs. It took awhile to make 20 feet but I didn't hurt the equipment and I keep it straight. But if you think you might be there again the sand would work better than kittylitter.
    l84work and Papa T Thank this.
  4. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    I was on night shift pulling loads of canned pudding out of a Dean Foods plant in Benton Harbor to a labeling plant near Coloma, MI, a distance of nine miles. Nine loads would be a nights work. On the second empty return to the pudding plant, I had to make several attempts on the small grade from the Paw Paw River to I-196 due to black ice. After returning with another load, I phoned the county road commission. I asked when they were going to sand the road. I could overhear the county dispatcher talking to the snow plow driver. The snow plow driver stated that he would stay on his regular route, clearing the residential streets first. It would be several hours before the two-lane highway was sanded in spite of my description of the black ice conditions. At that point, I called it a night and went home.
  5. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I drive milk truck and often find myself out at 1-2a.m. when there are no salt trucks around. The two musts in my tool box are chains and a few 50lb bags of barn lime. A few weeks ago we had an ice storm, and at about 2a.m. I was going up a hill on a back road with one pair of chains and both drive axles fully locked and I spun out about half way up and started to slide backwards. As soon as I touched the brakes, my fronts locked up and I slide sideways into the ditch. The only way I got out was to chain up the other side and use alot of lime to get my front up out of the ditch. Chains are great, but only go so far when you can not turn.
  6. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Are you sure there's no problem in using lime? I know there's lots of environmental laws that I don't know and I wouldn't want anyone to pay a big fine for dumping some regulated material on the ground. You can't even wash your truck now anywhere you like because of the run off so I just do not know.
  7. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    what about that "ice melter" stuff they have? or kosher salt? it is pretty cheap
    this automatic traction control on my F'liner is a pain when slick does ALOTT of enguaging and disenguaging of the axles. very tough to "burn through" the ice that way:biggrin_2552:
  8. dockthumper
    dockthumper Light Load Member
    50
    12
    Jul 27, 2008
    Owen Sound, ON
    Small bag of salt will do it, just enough to help you get going. You can also throw your chains in front of your drives, just don't forget them on the road.
  9. panhandlepat
    3,255
    2,243
    Jan 12, 2007
    we don't have chains, CO. policy is ICE= no drive. guess they dont understand that SNOW becomes ICE when packed by warm truck tires, LOL:biggrin_255:
  10. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I would assume there would be no problem since farmers use the lime for walkways in their barns, which are then scraped, and it is spread on the fields.
  11. walleye
    walleye Road Train Member
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    When I was a local route delivery driver running around the backwoods op here,...I would usually try to keep the right wheels on the shoulder and gain traction there,.....Just don't get to far over and get sucked into the ditch!!...
