when is E-logs required
Discussion in 'Experienced Truckers' Advice' started by mangdriver, Oct 25, 2017.
  1. mangdriver
    mangdriver Light Load Member
    61
    57
    Feb 13, 2016
    With the e-logs comming out I want to make sure we are compliant. We have one drive with two trucks. One truck is a 99 F550 and the other (main truck) is a 2005 F550. We drive mostly under the 100 mile exemption, but occasionally go over the 100 mile (about once or twice a month). With some of these times renting a twin screw tractor from penske. Do we need to look at a simple e log system, or can we manage with using the exemptions
  3. ladr
    ladr Road Train Member
    1,383
    15,431
    Apr 14, 2013
    GA
    No log required as long as you do not go over the 114 mile more then 8 days in a rolling 30 day period.
  4. Ridgeline
    22,625
    120,396
    Also as we have had an issue with this recently, we run paper on those runs over the exemption for some dedicated customers, one is 160 miles beyond and both Michigan and Indiana said it was alright as long as it isn't a regular occurrence with a majority of the work within the exemption range.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Fist is those trucks are over 10k lbs. So you must follow all logging rules. To get the short haul timecard exemption you need to meet three criteria.
    1. No more than 100 air miles, which you admited to.
    2. Must start/stop at the same location.
    3. Must not work more than 12 hours.
    If you meet all three you can use a timecard. If you go beyond either three criteria you must fully grid log.
    Now, if you do use the timecard, you do not need an eld. If you grid log you only need an eld if you go over 8 days in any 30 day period
    Bean Jr. Thanks this.
  6. mangdriver
    61
    57
    Feb 13, 2016
    We currently use the time card exemption, as the majority of our loads are under 40 air miles. Though I thought the daily time limit was 14hrs.
  7. 25(2)+2
    18,756
    45,804
    Sep 18, 2006
    the road less travelled
    Over 12 hours is supposed to require logging.
    ZVar Thanks this.
