When it rains
Discussion in 'Peterbilt Forum' started by Swampdonky, Oct 2, 2014.
  1. Swampdonky
    Swampdonky Bobtail Member
    8
    Paradise tx
    2000 379 with 60 series when it rains motor spudders and smokes white. Doesn't matter rpms or gear. Only happens when throttle is slightly pushed. It will quit when I press on throttle or let all the way off. I can put it in neutral and play with the throttle and it will do it also. As soon as i run out of the rain it will run normal. No white smoke at start up. Any ideas?? New ecm 2x Inframed, new head and new injectors, new boost sensor and lots of other new parts!
  3. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    I would venture a guess and say it's somewhere in your harness. A connector somewhere with a bad weather pack.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    FT. window leak,wet boots T.P.S on inside of fuel pedal geting wet. replace tps. 30$ and ck conn. at plug in wires for rubber seal split?
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    when i had a 379 it would have similar ishues...we determined that it was getting rain in the air intakes and the water was closeing them up since hey were watter blocking filters
  6. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    What??????
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    Never heard of them, where can I buy some? I want to drive my truck across a river and don't want the engine ingesting any water.:biggrin_2551:
  8. wore out
    wore out Numbered Classic
    15,988
    193,569
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    It's easy to say rain affects an external breather. In reality all trucks take unfiltered air in from outside the hood. Frieghtliner used to pull air in from the top right behind the hood and in front of the windshield. Perfect place for water to be taken in but I have never seen one affected by rain.
    It's most likely electrical. A helper and a spray bottle on a sunshiny day will probably show the culprit.
    Swampdonky and bullhaulerswife Thank this.
