When outside lights are on right turn signal don’t blink
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, Apr 5, 2018.
  1. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    Hi guys I’m having an electrical problem I believe . It’s on a 1995 t800 with a trailer .
    I noticed when all my outside lights are on my right turn signal light don’t blink or clicks. My left one works fine .
    When I turn off all my lights my left one still works fine but when I switch to the right, the front signal light works but my back tractor lights both blink like if I had my hazards on . Except the left back one dimmer than the right .
    When my right one is blinking the dash lights inside can blink with it also . Another thing I noticed when I turn on my outside lights my right signal indicator inside cab turns on with lights but won’t blink when I put switch to the right signal light
  3. xsetra
    xsetra Road Train Member
    5,161
    7,092
    Aug 21, 2011
    Bad ground, bulb in one of the lights could be bad. Turn switch bad.
    Do you have led lights,yes, no?
    Truck , trailer or both?
    Nestor Thanks this.
  4. RET423
    RET423 Medium Load Member
    432
    534
    Apr 6, 2017
    Kalifornia
    Plus one on the bad ground suggestion, check the white wire in the 7 way connector first.
    The tractor front turn signals are on the same circuit as the trailer turn signals, the tractor rear turn signals are a separate circuit; usually a problem that shows up on a front tractor signal light will be mirrored on the trailer.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,518
    6,576
    Aug 26, 2014
    Turn on your lights and right turn signal. Unplug or take the bulbs out of your right turn lamps one at a time. When it starts flashing again your know it is related to that light. Unplug the trailer first to eliminate it.
  6. Nestor
    160
    23
    Oct 21, 2015
    Yea it has led lights . I was looking everywhere for a ground I can’t find it .
  7. Nestor
    160
    23
    Oct 21, 2015
  8. Nestor
    160
    23
    Oct 21, 2015
    I unplugged trailer first thing I did. And what do u mean take out bulbs .? Like disconnect outside lights one at a time or ?
  9. Nestor
    160
    23
    Oct 21, 2015
    Sorry man I understand . Didn’t think of that I’ll try that first thing thanks man .
