When to use suspension dumps
Discussion in 'Questions From New Drivers' started by dogchimp, Oct 7, 2013.
  1. dogchimp
    dogchimp Medium Load Member
    673
    190
    Jan 31, 2013
    So I got a new truck today, went from a 48 inch sleeper to a 72 I think, any way the truck has dumps on the suspension, and I'm excited to have them, but need help understanding when to use em
  3. Bikerboy
    Bikerboy Light Load Member
    299
    183
    Apr 1, 2008
    Canada
    I only dump suspenion when unhooking a loaded trailer after you put the landing gear down
    chopper103in Thanks this.
  4. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    I rarely dump the suspension on my truck. About the only time I do drop it is when I drop a trailer. When you dump the valve before backing under the trailer and then inflate the suspension, it can take some stress off the landing gear which can make it easier to crank up.
  5. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    Sometimes I have to drop my loaded trailer on a scale. I lower the legs til they just touch the deck. Then I dump my bags and pull out. Also when I'm making a delivery on a logging road with steep inclines I'll dump my bags when I'm empty to gain more traction.
  6. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Dumping the suspension will give you a little more traction in the white stuff.
    The Challenger and baha Thank this.
  7. Highway101
    Highway101 Road Train Member
    1,145
    693
    Sep 19, 2011
    Fallon, Nevada
    I used the dumps when I drop a loaded trailer, after the landing gear is down.
  8. Wolfyinc
    Wolfyinc Road Train Member
    2,888
    966
    Apr 21, 2013
    Salem, or
    use the dump when moving 5th wheel, other than that I dont really use it much
  9. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Drives or tandems or both?
    And can you explain how that works?
    Mikeeee
  10. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    I had a 10 ft spread and mine only dumped the front axle on the spread for turns.
  11. bbigcnote
    bbigcnote Light Load Member
    194
    107
    Dec 29, 2008
    northeast, missouri
    i use mine to sneak under low things gives me another 4 to 5 inches
    Moon_beam Thanks this.
