When would one use a 22.5 x 9.00 rim?
Discussion in 'Questions To Truckers From The General Public' started by trucking_noob, May 6, 2012.
  1. trucking_noob
    trucking_noob Bobtail Member
    27
    Apr 6, 2012
    Vancouver, BC
    Hi, I asked a variation of this question in a previous post but thought I'd ask again as it may have been buried in the post.
    When would you use a 22.5 x 9.00 rim (as opposed to a 22.5 x 8.25)? I see in the Accuride catalog that it is listed as a "heavy load" application (10,000 lbs vs. 7,400 lbs). Is this a common size?
    Can anyone tell me who uses a 22.5 x 9.00 and under what circumstances? (Is it just to control sidewall flex or are there certain kinds of hauling scenarios where one would prefer a rim that can handle a heavier load.)
    On the same note, if someone can help explain how the 10,000 lbs vs. 7,400 lbs max load works that would be great (e.g. 7,400 x 4 = the maximum load on the axle?).
    Any answers would be greatly appreciated!
  3. fortycalglock
    fortycalglock Road Train Member
    6,156
    6,586
    Jun 25, 2011
    Tourist Town, FL
    When you want to use a tire wider than the standard 11r22.5 to increase the weight on the front axle. Typical would be a 12r22.5 tire or 315/80r22.5
  4. Fantomaz
    Fantomaz Bobtail Member
    Malawi
    responses very good! )
