Where and Who to buy a radiator from
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chuy1978, Oct 26, 2010.
  1. chuy1978
    chuy1978 Bobtail Member
    32
    Dec 26, 2009
    Indianapolis,in
    I need to know where to buy a radiator?
    I have a Pete 379 with a bad radiator need help!!!!!!!!!
    ANY ONE CAN HELP
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Check out Detroit Radiator. I screwed up and bought one from someone else assuming I would get the 5 row staggered but ended up a straight 5 row. It doesn't cool as good.
  4. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Duralite? :biggrin_2556:
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I didn't know there was a staggered type. I thought just 2-3-4 row e.t.c.
  6. Les2
    5,150
    2,288
    Jul 25, 2008
    Go look at their site you will see what I'm talking about. Believe it or not it makes a big difference too!
  7. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    Just recently, I read somewhere that the staggered rows actually decreased flow. After looking at the drawings comparing staggered vs straight, I would tend to agree. IIRC, this was in an advertisement comparing different brand radiators; another thing that caught my eye, was that the tubes on the four tube radiators appeared larger, looking like they would do a better job of cooling, BUT, I am not an expert in hydraulics.
    Matter of fact, I am not really any kind of expert.....just don't tell anyone, OK?
  8. Les2
    5,150
    2,288
    Jul 25, 2008
    From personal experience, the staggered is by far the better radiator. I don't care what any study says.
    Go look at them and you will see there isn't much difference but just enough to cool better.
    droy Thanks this.
  9. mslashbar
    mslashbar Medium Load Member
    601
    808
    Jul 22, 2009
    elizabeth,co
    Anyone know how hard it is to r&r your tanks off the old radiator so you can just buy the core? It looks like it's just time consuming with all the bolts. TIA
  10. Les2
    5,150
    2,288
    Jul 25, 2008
    Its easy. Just take the ATA off and lay the old radiator on some saw horses and go at them nuts and bolts with a 1/4 inch drive gun.
  11. Independent
    Independent Light Load Member
    70
    17
    Oct 6, 2010
    With a diesel you don't want to add too much cooling because then it will be running cold most of the time which will kill engine life.
    Bigger radiators are not better with a diesel.
    If you are overheating on grades you probably need to learn how to operate the engine by keeping the rpm's up high and the fan blowing the heat away when pulling hills.
