Where can you find the spn codes for a international prostar?
Discussion in 'International Forum' started by jlafume, Nov 11, 2018.
  1. jlafume
    jlafume Light Load Member
    241
    324
    Jan 6, 2011
    Victorville,Ca
    Have code spn 51 FM 8 does anyone know what means the engine is a 07 Maxxforce
  3. Heavyd
    Heavyd Road Train Member
    7,767
    6,204
    Feb 4, 2009
    There are different lists for different modules. 51 is likely from the engine as it for the intake throttle valve. I do not have FMI 8 in my list though. Where are you getting this code from?
  4. jlafume
    241
    324
    Jan 6, 2011
    Victorville,Ca
  5. jlafume
    241
    324
    Jan 6, 2011
    Victorville,Ca
    It like miss fires somtime when I'm idling or crusing down the road and that's the code its giving me
  6. Heavyd
    7,767
    6,204
    Feb 4, 2009
    Check the connector at the intake throttle valve for corrosion. There is also a terminating resistor sticking out of the harness near by. Earlier ones had the end of the connector sealed with a big heat-shrink tube that wouldn't make a proper seal, allow water in, and cause corrosion.
    jlafume Thanks this.
  7. jlafume
    241
    324
    Jan 6, 2011
    Victorville,Ca
    Thanks will check it out in the morning
  8. QUALITYTRUCK
    1,804
    1,765
    Jun 14, 2009
    romulus,mi
    HeavyD is correct again. That terminating resistor causes many issues....
    Heavyd Thanks this.
  9. jlafume
    241
    324
    Jan 6, 2011
    Victorville,Ca
    Heavy d were is the intake throttle valve located?? Thanks
  10. Heavyd
    7,767
    6,204
    Feb 4, 2009
    Left side of the engine where the air to air pipe connects.
