If you are on your hometime where do you park your rig when it is cold and needs to be plugged in? I live in Reading, PA. I am considering a job with a company that does not have a terminal near me. They said possibly a Walmart would let me park it there. But where do you go if you need to plug it in? Any ideas?
Where do you park it and plug it in?
Discussion in 'Questions From New Drivers' started by Dennis in SE PA, Oct 24, 2007.
Page 1 of 3
We now have a re landscaped yard, meaning half the yard is white rock driveway, so that he can bring the tractor home and plug it in.
We don't live in the city limits, so its not a problem here.
I always thought that RV parks could make extra $$ in the winter providing spaces for trucks to park and plug in at night. You might try that route if you have one close. -
Another option is to talk to local trucking cos, in the Reading area. You may be able to work out some parking arrangement with them, since you need to plug in.
Just wondering why you need to plug in, I have never plugged in and the trucks have always started up quickly. Worst case scenario, give it a small shot of ether and go! -
I was told by my prospective company that they should be plugged in when it gets cold out. I am new to this diesel thing.
Gelling is when the parrafin (wax) in the diesel partially solidifies into (you guessed it) Gel, plugging up lines and clogging fuel filters.
The last co. I drove for would reimburse us for FPPF, an additive that is supposed to prevent gelling. So I would add it and keep going, and never plug it in. Now, LSD (Low Sulfur Diesel) wouldn't gel unless it got REAL cold (think Fargo in winter); ULSD (Ultra-Low Sulfur Diesel) is a newer thing, so we will see what happens this winter. But the only problem I have heard of is with BIODIESEL; that seems to want to gel at much lower temps (around 10-15 Deg F). -
So low sulphur fuel is more resistant to gelling?
No wonder I had so much trouble getting heavy equipment started in the winter. -
Well, from what I have read and heard, ULSD should be like LSD, at least as far as gel point is concerned. But Biodiesel supposedly gels at warmer temps, getting cloudy around 10-20 Deg F.
Talk to a local truck dealership. Sometimes they will help a fellow local out and give you a place to park your rig at the back of their dealership.
ULSD has a higher gel point compared to LSD. Many truckers found this out last year when they gelled up at temps not normally using the anti gel.
Can you plug and park in truck stops? I've never seen plugs at the Flying J or Pilot, for example, and I know it's darn cold in the NE USA and Canada. We can park at home and plug in but where on the road???
Page 1 of 3
