Got a 07 volvo 780 with cummins isx450 low coolant light on poured in 2 and a half gallons of coolant and its still not filling reservoir and light still on never been this low check for leaks can't find em need help. Never been this low had new egregious valve put in November replace fuel filter in December when we had the super 30 below weather need help guys thanx
Where is it?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 780krazy, Feb 3, 2014.
EGR cooler is usual culprit of coolant loss.
EGR cooler would be the first thing I look at as well.
Yep thanx getting it replaced had a pressure check done came up fine
Dont rule out the trans cooler. Some fro transmissions have internal oil coolers. Also depending on the specs at build it could have a water to oil trans cooler. I have seen both fail.
Ok thanx guys truck fixed next question . Does anyone have any information about landstar I've been looking at the company for a while are they as good a company to work with? And what about mercer heard anything about them? Looking for someone to lease on to .
Had a 08 volvo that leaked coolant into the regen system and burned off
Landstar and Mercer both have their own sub forum's here with a wealth of information, also check out farm to fleet.
