Where is my power stearing fluid?? No visible leaks.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 02 pete c15, Jul 13, 2017.
  1. 02 pete c15
    02 pete c15 Bobtail Member
    i have an 02 cat c 15 gear drive p/s pump resevior empties in one hour no leaks... happened today havent looked at engine oil yet...can p/s fluid get into engine somehow with this type pump?
  3. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Power steering is a closed system. If the fluid is disappearing, you DO have a leak. You just haven't found it yet.
    Edit. Gear drive just means you aren't using belts and pulleys to spin the pump.
  4. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    Yes, it can get into the oil from the pump driveshaft seal. Is your oil getting over full?
    Grubby and AModelCat Thank this.
  5. dngrous_dime
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Well, I apparently learned something new today.
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    i would say your pump is putting oil thru in the engine not that common to happen but it does happen.
  7. AModelCat
    156,550
    Yep if the front seal on the pump pukes, it goes into the engine.
  8. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    You are not incorrect . But if losing fluid , if it's not leaking out its leaking in.
    Grubby and dngrous_dime Thank this.
  9. Jonrulerofearth
    Jonrulerofearth Light Load Member
    232
    340
    Sep 1, 2011
    Hueytown, Al
    Sounds like the Russians again......
  10. 02 pete c15
    thanks men..... oil was overfull leaking in not out LEARN something new everyday Thanks again
  11. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Yeah ! It's the Russians again...
