Where is the 40 ft point on the trailer?
Discussion in 'Questions From New Drivers' started by TawcoTruck, Jul 11, 2023.
  1. TawcoTruck
    TawcoTruck Light Load Member
    155
    224
    Dec 11, 2022
    Going into California tomorrow.
  3. Chinatown
    Chinatown Road Train Member
    76,754
    178,753
    Aug 28, 2011
    Henderson, NV & Orient
    A semitrailer not more than 53 feet in length shall satisfy this requirement when configured with two or more rear axles, the rearmost of which is located 40 feet or less from the kingpin or when configured with a single axle which is located 38 feet or less from the kingpin...."
    Quick Guide: Truck Lengths & Routes | Caltrans
  4. RockinChair
    RockinChair Road Train Member
    5,229
    13,503
    Feb 19, 2012
    Lubbock, TX & thereabouts
    If it's a 53 ft trailer with a 3 ft kingpin, 40' is 10' from the very back of the trailer.
    TripleSix, Speedy Sailor, Numb and 2 others Thank this.
  5. tscottme
    tscottme Road Train Member
    If you had a $15 Rand McNally Motor Carrier Road Atlas it would have the answer to your question about CA and for every other state. No CDL driver should drive without it. It also lists the restricted routes for trucks in every state and low clearance locations in every state. At the end of the year you buy last year's version for sometimes as low at $10. They are the best purchase you can buy in trucking.
    This is what they look like. I would not spend extra for the laminated page version.
    https://www.amazon.com/Rand-McNally-Motor-Carriers-Atlas/dp/0528027204
  6. bryan21384
    bryan21384 Road Train Member
    15,402
    33,517
    Sep 18, 2009
    Memphis, TN
    40 foot mark is somewhere around the 5th or 6th hole I think. You need to grab a tape measurer to be sure
  7. Numb
    Numb Crusty Curmudgeon
    4,224
    9,908
    Jan 30, 2012
    Charlotte, N.Carolina
    yup, 10', the swing door is 4', so twice as far as that.
    tscottme Thanks this.
  8. Moose1958
    Moose1958 Road Train Member
    15,259
    33,821
    Dec 17, 2010
    Williesburg, Virignia
  9. Sixela918
    Sixela918 Light Load Member
    257
    397
    Nov 24, 2021
    Phoenix, AZ
    Where to in Ca, from where?
  10. Sixela918
    257
    397
    Nov 24, 2021
    Phoenix, AZ
    The reason I was asking is, if you're coming in on i10, going to Bakersfield or North, just take AZ95 North at Quartzsite, > Parker, > vidal junction > i40 in needles. You can skip the banning scale. The small one in Mojave is closed after about 6pm at latest. Check truckerpath
