Where is the Blower motor on a Pete 520 cabover?
Discussion in 'Peterbilt Forum' started by Monti, Aug 27, 2022.
  1. Monti
    Monti Bobtail Member
    I have no air coming out of the vents. The fuse keeps popping when I turn the ignition on. I would like to find where the blower motor is on my 2022 Peterbilt 520 cabover garbage truck so I can disconnect the power plug and isolate the short. Is it the motor drawing a lot of amps or is it the wire harness?
  3. kranky1
    kranky1 Road Train Member
    2,254
    8,796
    Sep 16, 2015
    Ontario, Canada
    Sounds like the blower motor is toasted. Could be a chafed power wire grounding off but I’d suspect the motor first. Not sure where the heater box is in those, but I would think under one of the removable panels on the top of the doghouse would be a good place to start looking.
  • Draft saved Draft deleted
