Where is the blower motor?
Discussion in 'International Forum' started by texasmorrell, Mar 27, 2015.
  1. texasmorrell
    texasmorrell Medium Load Member
    597
    625
    May 3, 2012
    Lone Star State
    My blower motor for the climate control system has gone out. I only have air movement now when the truck is moving. I need to know where the blower motor is and how to access it so I can change it. If anyone has any experience with this please let me know the steps. I have an 09 ProStar.
  3. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Right hand (passenger) side, mounted against the firewall. Access should be from the engine compartment side... it's been a really long time since I've done one, so I'll take a look at one tomorrow to refresh my memory, unless someone with better memory of it posts before I get a chance to.
    texasmorrell Thanks this.
  4. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    I have a 2011 prostar and had to do this this past fall and mine is passenger side under the fuse box, pop the panel on the passenger side inside (one with thr big international logo on it) then remove the bolts and pop the bottom part off you will see the blower motor down at the bottom near where ur feet would be. Be Careful as alot of wires run thur this area also.
    hope this helps.
  5. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Also, the blow motor comes alone and not with the squirrel cage fan. You have to take the old one off. They are not strong at all and if you warp it then it will make noise. You may want to take the motor and fan to the dealer and have them switch the fan blades to the new motor.
  6. Fajo
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Interesting, mine came with the whole assembly, I took out the old and thur in the new one. Bought the part strait from International maybe that's the difference ?
  7. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    Fajo is spot on.Blower for 9200 does not come with cage.Prostar and 4000 series does.
  8. texasmorrell
    597
    625
    May 3, 2012
    Lone Star State
    I bought mine today. It has the cage already.
  9. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Great! Careful putting it in so you don't bend the fan. I have first hand experience with that!
  10. HOTSHOTTER432
    HOTSHOTTER432 Bobtail Member
    48
    55
    Apr 20, 2015
    PERMIAN BASIN
    Good info! My 99' 9200i's fan seems to have gone out too. I will save the fan blade when I swap it out.
  11. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Start this thread again,
    2010 T800 ac/heater blower where it located?
    Only has warm air coming out when moving, hit a good bump and she works again; until the next bump!
    Any thoughts?
