Where is the Brake light switch on 2000 Volvo VNL
Discussion in 'Volvo Forum' started by jayfarmlaw, Dec 28, 2020.
  1. jayfarmlaw
    jayfarmlaw Bobtail Member
    30
    11
    Dec 12, 2020
    2000 Volvo VNL, Cummins M11, Super 10, single axle- Ex Fed Ex truck if that makes a difference.
    Where is the best place to tie in to a hot brake light wire (down stream from the switch) to install an electric brake controller? I can hear the relay in the fuse panel, but cant find the wire and don't want to go poking wires at random.
    For that matter, where's the brake light switch?
    Thanks in advance for your response.
    Happy New Year!!
    Jay
    Old Man Thanks this.
  3. DUNE-T
    DUNE-T Road Train Member
    6,982
    16,949
    May 10, 2015
    Detroit, MI
    It's behind the cluster. There are two similar looking ones, it's the one on the left
    jayfarmlaw and QUALITYTRUCK Thank this.
  4. loudtom
    loudtom Road Train Member
    1,717
    2,802
    Aug 26, 2016
    You can run a wire into the fuse box under the hood and into the trailer brake relay output pin. You can strip the wire and wedge the relay in with it. Since there's no splicing or soldering involved, you can always remove the wire and it's back to stock.
    jayfarmlaw Thanks this.
