Where should I mount my FM transmitter for Sat Radio
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Wiseguywireless, Jan 25, 2009.
  1. Wiseguywireless
    Wiseguywireless Road Train Member
    1,693
    801
    Dec 21, 2007
    Petoskey, MI
    I have to use the FM transmitter for my Sat, for now, I drive a Freightliner Columbia 2006 and I was wondering where the best place is for the transmitter.... ????
  3. 48National
    48National Bobtail Member
    20
    7
    Jul 10, 2008
    Knoxville, TN
    On my old unit, I found the closer it is to the deck the better they usaully work (strange b/c u would think putting it closer to the antenna would be better).
    Just my own opinion, if you don't have a tape deck, I'de use one of those Hardwire hookup's that plug into the Antenna port on the back of the deck itself (I've seen them at T/A's, might be at other truck stops too). I've used a few Transmitter type setups and can't stand it when my station gets changed to a strong signal from a local broadcast, not to mention the quality just isn't as good as a hard wire. Make sure you u can remove your deck easily and string a wire out somewhere before getting one though...
  4. YankeeTexan
    YankeeTexan Light Load Member
    222
    194
    Jan 1, 2009
    Houston, Tx
    does your radio not have an aux input? that is about the best way to hook it up.
