Where to buy chains?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by orphan andy, Jan 8, 2012.
  1. orphan andy
    orphan andy Light Load Member
    Jul 25, 2011
    59
    Thanks Received:
    4
    What's the best place to buy chains? Will consider used.
  2. Oscar the KW
    Oscar the KW Going Tarpless
    May 19, 2011
    12,247
    Thanks Received:
    28,119
    What kind of chains? Tire chains or chains for load securement?
  3. blackw900
    blackw900 The Grandfather of Flatbed
    Jul 12, 2009
    5,817
    Thanks Received:
    7,678
    A.W.O.L
    If you're talking about tire chains....Try a truck supply house. That will be cheaper than buying them at a truckstop.
    The larger question that needs to be addressed here is "When to buy them?"
    I always buy my chains in the "off" season because they're way cheaper then....Food for thought.
  4. orphan andy
    Jul 25, 2011
    59
    Thanks Received:
    4
    Whoops, tire chains.
  5. otherhalftw
    otherhalftw R.I.P.
    Nov 18, 2008
    13,081
    Thanks Received:
    45,332
    CA...gold discovery foothills
    If you're buying used chains...not in the bag...better make sure they are the right size!
    Most drivers really like the practice of putting them on....have fun!
  6. blanco
    blanco Road Train Member
    Nov 20, 2009
    1,221
    Thanks Received:
    296
    Gwinnett County, GA
    Chains on tires? whats that for? /sarcasm
    Southeastern ftw!!
  7. otherhalftw
    otherhalftw R.I.P.
    Nov 18, 2008
    13,081
    Thanks Received:
    45,332
    That is how they get the "rumble strips" into the asphalt!:biggrin_25524:
    striker Thanks this.
  8. HISPEED428
    HISPEED428 Light Load Member
    Mar 28, 2009
    157
    Thanks Received:
    21
    Plum Coulee,MB
    White Mountain Chain.
  9. orphan andy
    Jul 25, 2011
    59
    Thanks Received:
    4
    Thanks, will check wmc
    2) i guess the other question is, you would need at least 4 chains? One for each drive wheel on a 6x4 tractor UNLESS you have diff locks for both axles? Not the inter-axle lock, but actual diff-locks that lock both sides of each axle together?
  10. Krooser
    Krooser Road Train Member
    Jul 25, 2010
    2,493
    Thanks Received:
    1,066
    Wisconsin
    Each state has it's own requirements for the minimum number of chains you must carry.
