Where to check VED D12 injectors
Discussion in 'Volvo Forum' started by bravoo67, May 4, 2012.
  1. bravoo67
    bravoo67 Light Load Member
    252
    35
    Mar 15, 2012
    Brooklyn NY
    Hi im from NY and have volvo with VED D12 engine. I was wondering are there any independent shops where I can send my injectors in
    just for checking/adjusting or rebuilding?? The only available place I know
    is volvo dealer where price for injector without core charge can be really expensive
    Anybody knows any independent shops??
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    use VCADs pro to check injectors on engine. It is easy.
    some D12D and D12F got new injectors impossible to rebuild (Delphi, twin coil), so.... prepare pocket to be slimmer
    bravoo67 Thanks this.
  4. bravoo67
    252
    35
    Mar 15, 2012
    Brooklyn NY
    Will check them again on cold engine.. maybe that will give me clear answer
    Thank you!
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    VCADs run cyl. ballancing test with over 70 DGR C coolant temp, and engine ECM starts self ballancing at over 70 dgr C.
    I'd run this test at 900 RPM. If you see more difference - change injector.
    The only part of injector you can change is nozzel assembly....
