Where to find local work NYC? 26 foot dry box with lift gate
Discussion in 'LTL and Local Delivery Trucking Forum' started by Big Herb The Trucker, Jun 10, 2017.
  1. Big Herb The Trucker
    Big Herb The Trucker Light Load Member
    84
    40
    Jun 10, 2017
    NYC
    This question is for my fellow owner operators working in or around NYC: I have done all my research and know what is need to get started. I am in the process of getting my dot numbers and buying a 26 foot truck with lift gate. I see a lot of postings on craigslist for local work, but are there any other places I can get local delivery work for my truck? I am buying either a freightliner m2 106 or a International 4300 both are going to be under 26,000 lbs as I don't have a CDL. Any help finding other sources for work would be helpful. Thanx in advance.
  3. Ruthless
    Ruthless Road Train Member
    8,933
    87,867
    Aug 28, 2010
    The City.
    Furniture warehouses (i.e. Bobs discount furniture/other big furniture retailers) mail, warehouse transfer, home appliance delivery warehouses, dry goods distribution centers.
    brian991219 Thanks this.
  4. Big Herb The Trucker
    84
    40
    Jun 10, 2017
    NYC
    Yeah I see all the furniture and Appliance delivery stuff on craigslist. I really don't want to do furniture and Appliances there are a lot of walk ups in the city. I am not lifting a fridge up 4 flights of stairs.... Not going to happen. Where would I find the dry goods, mail or warehouse transfers?
  5. Ruthless
    8,933
    87,867
    Aug 28, 2010
    The City.
    Warehouses in nj, same as the furniture n appliances. Mail is a process from. What I understand. Get vetted, go thru all the beauracratic stuff, then wait for a run to come up for bid that you want n have the equipment for. Might be a week might be 5 years.
    What you're up against is that you've bought equipment that's primarily used for household deliveries with lots of labor.
    Go to every warehouse you see trucks same size as yours coming n going from and talk to who you need to talk to there to find out who has work for you.
    brian991219, Sho Nuff and Dye Guardian Thank this.
  6. jeastonjr
    jeastonjr Light Load Member
    99
    120
    Nov 4, 2013
    Weymouth,Ma.
    Around NYC I would be looking a 12'6" height. You can still get a fork lift in and be low for overpasses.
  7. Sho Nuff
    Sho Nuff Road Train Member
    1,175
    1,401
    Apr 9, 2015
    See if you can contact your services to a HCR Mail Contract Carrier. I've talked to a couple O/O Tractor Trailer Drivers and a lot of them do it this way instead of bidding on routes. Clifford B Finkle is big around the NYC/North Jersey area and they use a lot of straight trucks. I think Postal Transport owns Finkle and I've seen them hauling Beam Bros Trailers as of lately. I don't know if they got some of Beam Bros work because Eagle Express Lines took over Beam Bros.
    If you do get contracted with a Mail Contract Carrier, the work is very easy. Most of them pickup Mail at the smaller Postal Stations that Tractor Trailers can't fit in. They do everything from picking Mail, Parcels, FSS Flats, BMEU, Air Port Express (which can NEVER EVER be late), and so on and so forth. Everything is on wheels, so you just push the Mail off. Very simple work.
  8. Sho Nuff
    1,175
    1,401
    Apr 9, 2015
    You can also try Fed Ex as well. They have a big terminal by Newark Airport. Fed Ex Custom Critical and Fed Ex Ground hire Straight Truck Independent Contractors/Owner Operators. But word to the wise though, they recently got sued and had to pay out $227 million for misclassification of job title. But it MAY be an option, if they can ever figure out WHAT an Independent Contractor actually is.
  9. DTP
    DTP Road Train Member
    1,281
    2,708
    Dec 9, 2014
    Local driver in NYC, can't say I envy you ;)
  10. Big Herb The Trucker
    84
    40
    Jun 10, 2017
    NYC
    Ok will do thanx for the advice.
  11. Big Herb The Trucker
    84
    40
    Jun 10, 2017
    NYC
    Its not as bad as people outside the city think when you do it everyday it becomes normal.
    Dumdriver Thanks this.
