Where to get wiring diagram for my Western Star?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Floyd, Oct 13, 2011.
  1. Floyd
    Floyd Light Load Member
    163
    25
    Jun 1, 2010
    Central Maine
    I'm having electrical issues with my '95 W. Star. The truck had been sitting for a few months. I was taking it over to the shop to service it before using it again and the engine quit on me. I could hear the electric/air fan solenoid clicking on and off and the tach was going crazy. It wouldn't start at first(just turned over) then it fired and ran. This happened several times. Everything else has power but it seems that the ECM is losing power intermittantly for some reason.
    I used my cruise switch to pull a 34 code which was something to do with RPM signal.
    I'm hoping it's a bad connection somewhere but i'm starting to have my doubts.
    If had any thoughts or knew where to get a wiring diagram that would be great.
    Thank you.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I sugest it shares a lot with Freightliner Classic. Anyway, simple wiring
  4. Heavyd
    Heavyd Road Train Member
    7,785
    6,222
    Feb 4, 2009
    Most engine ECMs get their power from a dedicated wire harness straight from the batteries. Normally there are a couple of connectors and a fuse in there somewhere. These are perfect locations for corrosion to set in. Try checking for this harness and follow it the best you can and check all the connections.
    SHC Thanks this.
  5. fortycalglock
    fortycalglock Road Train Member
    6,156
    6,585
    Jun 25, 2011
    Tourist Town, FL
    On my 2000 WS, the ECM power wire goes to the firewall above the engine, through a fuse, terminates and then goes to the battery box. I'd check this first. Also make sure your battery terminals are tight. I've had a ring terminal break off and kill power to the truck while riding down the road before.
    SHC Thanks this.
  6. billm89
    billm89 Bobtail Member
    39
    19
    Jul 20, 2011
    Mass.
    If you have access to a computer, go to www.accessfreightliner.com.Click on the register for access link and there is a form to fill out to be able to log on for vehicle specific parts and wiring diagrams. It's faster if you bring the form to your local dealer, and they can get you hooked up. I have used this site quite a bit both for parts lookup as well as wiring info and it's excellent. You only have to register once, and they give you a password that you use anytime you need to get on. Good luck!
  7. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    1st check and clean all your grounds. Most all electrical issues are traced to bad grounds. I'm talking the grounds at the starter and where the cable goes to the frame. (be careful not to break the solenoid on the starter).
  8. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I just went thru this 2 days ago with my 04 Lowmax.... the ECM/DASH gets it's power supplied thru a dedicated wire harness that connects at the battery terminals. Mine had corroded connectors but I could not tell they were until I removed them and they fell apart. Take off the battery box covers and check. If you have dual boxes like I do, they will be on the drivers side box.
    Hope that helps
    04 LowMax Thanks this.
  9. Floyd
    163
    25
    Jun 1, 2010
    Central Maine
    Just an update. After a couple days in the shop chasing wires and checking connections, wires, grounds etc. the truck ran pretty well yesterday.
    I found that my switched power to the ECM seemed fine, but I ran a bypass wire from a known good power source just to be sure. Truck sat and ran for a while so I thought I had it............and then it shut off like it had been.
    Basically I was at the point where it had to be the ECM, but since the truck sat for a couple of months I was still hoping on a moisture issue so I hooked her up yesterday morning anyway and went to work(just locally).
    It shut down maybe 3/4 times and coughed a couple others before I could haul my first load, I thought great!
    But after the first few fits it ran like a top the rest of the day! Hopefully my theory on moisture was correct but only time will tell.
    SHC Thanks this.
  10. Harleychikka
    Harleychikka Bobtail Member
    MI
    Problem with that is they take 3 weeks to give you access, and that's if they approve you... i need an answer now...http://www.thetruckersreport.com/truckingindustryforum/images/smilies/roundies/biggrin_25521.gif
  11. SpeedRacer
    SpeedRacer Light Load Member
    143
    12
    Dec 4, 2007
    Tifton, Ga
    I 2nd the Access Freightliner, I use it a lot. It gives you access to all the same schematic and install diagrams the shop can see. If you need the schematics quickly though, a friendly dealer can look them up and print them for you. That's how I started getting them. Some may be less willing than others, doing business with them regularly helps.
