Where to lookup/find oem parts?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by irishluck09, Feb 9, 2020.
  1. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Like @pushbroom said, any pete dealer worth it's salt can look up part numbers, keep the last 8 of the VIN handy. Some will grumble about it because they'll need to break out the old hard copy parts manuals. Chris at MN Peterbilt has been a big help to me in the past, recommend him to you. Getting parts for the older stuff can be daunting, my 362 is an '86, but they are out there.
    Many times, pete would stamp the part # on the part, something like "20-12345", often though this # will have been superseded, so ask when you call if it has been.
    Over the years, I've driven macks, kw's, binders, shakers, fords, jimmys, you name it. Pete has it hands down, with mack (all mack) and kw a close second.
    Ever tear apart the dash on a modern shaker, all the wires are the same color. At least pete color coded and numbered their wiring, making it easier to trace and add or replace.
    Most, if not all, mfgr's now-a-days don't stock parts for anything older than 10 years, there's a reason for that, but it has nothing to do with the "quality" of the truck itself.
    Pete & KW, are the top two best o/o trucks out there, there's a reason for that.....
    pushbroom, SAR and spsauerland Thank this.
  3. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    Do you want to chance the clutch failing and sending your fan thru your radiator and charge air cooler?? The cost for that failure on the highway is going to be expensive.
    I wouldn't necessarily go the cheapest route on this.
  4. irishluck09
    irishluck09 Light Load Member
    271
    136
    Nov 24, 2019
    Whats wrong with just rebuilding my fan clutch? Thats all a remaned one is except the company rebuilds it and charge more for it.
    Im not just throwing duck tape on it and glueing it together lol Im getting a genuine rebuild kit for it and rebuilding my fan clutch properly. Not a chinese knockoff.
  5. AModelCat
    159,562
    Well I've tried rebuilding one in the past and to me, my time is worth more than the PITA factor of doing it myself.
    clausland Thanks this.
  6. clausland
    1,933
    11,067
    Dec 5, 2014
    North Woods
    I hear what you're saying, and normally I'd agree with you, but let me ask you this, have you ever rebuilt a fan clutch? If yes, then you know what it involves, but if you haven't I'd strongly suggest that you pay close attention to the various tolerances and steps necessary to do it properly, good luck to you.
    Like @AModelCat suggested, with some things, it's sometimes better to just get a good one and put it in, just my two cents...
    SAR and AModelCat Thank this.
