which balancer for my engine C15?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Lucar, Oct 31, 2013.
  1. Lucar
    Lucar Road Train Member
    1,396
    891
    Aug 22, 2012
    Texas
    Which engine balancer to buy for my C15 Cat?
    PDI, Pittsburg power, OEM Cat?
  3. rollin coal
    rollin coal Road Train Member
    13,249
    26,611
    Mar 29, 2008
    TN
    Damper? Vibratek, made in America - I believe that it's the same thing as PDI, and Pitts Power they just rebrand it. Was told by Haney CAT OEM uses Chinese silicone and is of poor quality - will not last as long.
    bigstank Thanks this.
  4. bigstank
    bigstank Light Load Member
    87
    19
    Mar 4, 2013
    missouri
    I agree with rollin coal vibratec is the only way to go, also use the mercury crank balancer that PP sells
  5. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    i put a vibratec damper on my 6nz seam to run alittle smoother i took the stock damper and cut it in half had over a million miles on it the silicone was still fluid good or bad i dont know but did run smoother with the vibratec
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    The damper does nothing till over 1500 RPM, many power units that run at 1800 do not have a damper so you can feel it?
    This is anouther sales pitch thread, on Cat warrenty you check the damper if it is not bent, visually, or when you take it off and bounce on the tire it rattles it is good.
    Just a thought!
  7. rollin coal
    13,249
    26,611
    Mar 29, 2008
    TN
    I don't get how a damper does nothing under 1,500 rpms? At a million miles it was just one of those things I figured it was time to replace. Not trying to be a sales pitch.
  8. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    They're supposed to be replaced at 500,000.
    I run a Vibratech from PP. I called Vibratech and was told just to buy it form one of their distributors and they told me to call PP.
  9. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Power units that run 1800 or more don't have a damper? Then I wonder why there was one on a 4L inline 6 in a Jeep Cherokee I had. Check the parts schematics.... yep, the 4L inline 6 had a crankshaft damper. So did the 2.8L inline 4 cylinder diesel in a 2006 Jeep Liberty I owned. And your concept on "testing" to see if a damper is good. You must be just trying to pull our lariats here. Do you have any real idea of what they are made of and how it is the components inside of it work? If it "rattles", it is staying off and getting replaced on my engine.
    I can't speak to every engine out there, but I do know for fact that Detroit, in the owners manual, recommends replacing the crankshaft damper at 500,000 miles.
    Cetane+ and DL550CAT Thank this.
  10. JohnP3
    1,594
    683
    Feb 21, 2010
    I have every Detroit manual there is and it does say to replace the damper at every major overhaul and if there is a crank failure. I did engine repairs and never replaced a damper except when a major overhaul kit was bought.
    I did maybe 2 of those overhauls the benefit of doing those was the warrenty available. Testing the damper that is done, Cummins has the same style kits available and it includes a damper.
    We had a few dampers, with the rubber rings fail while the truck was on the road, many were Cats, we told them to keep the RPM below 1600 and bring it in when he got back, The Dampers with the rubber had timming marks and you did have to look at the marks being sure they lined up.
    Detroit manuals have the damper in section 1.36. they are just covering their butt. If you replaced everything, in an overhaul, you might as well buy a new engine, then there could be a transmission problem or a rear gear problem, Might as well buy a new truck.
    Reality is that trucker do not make enough money to replace every part, you replace what is needed. Breaking a crankshaft, that is very rare, in a modern engine. I have removed a lot of dampers, to inspect them when there is an abnormal noise, I very much doubt I have replaced, a dozen dampers for a failure, in a damper that was not damaged in an accident.
    You can change a lot of things to extend the engines life, the oil is the one thing that does work.
    Every engine has a different arrangement, and characteristics, if the engine can rev higher than 1800, it may need a damper, some arrangements that rev higher do not. Some engines have extreme vibrations at certain revs the 1710 Cummins come to mind.
    Just a thought!
  11. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    JP3 do you even know what a damper is supposed to do? The way you talk you make it sound as if it's job is to balance the engine. Which by the way is not it's function.
    Cetane+ Thanks this.
