Which brand do you trust for plug-style USB chargers?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by SteveBausch, Sep 6, 2018.
  1. SteveBausch
    SteveBausch Light Load Member
    128
    55
    Oct 15, 2014
    Indianapolis, Indiana
    The stubby low-profile ones that accept 2-3 USB cables.
    Is that form factor a recipe for failure?
  3. Suspect Zero
    Suspect Zero Road Train Member
    2,511
    9,553
    Oct 10, 2016
    Burbank, IL
    Duracell seems to be the best in my experience. 2.1 amp can charge 2 things at once. Bought 4 of them over 2 years ago, still using the 1st two and the other two haven't even been opened yet.
    No other in the past has ever lasted like that.
    SteveBausch Thanks this.
  4. ttypewe4jim
    ttypewe4jim Light Load Member
    189
    142
    Feb 21, 2018
    Anker products seem to work really well, I've never had much luck with the multi connector style cords.
  5. snowwy
    snowwy Road Train Member
    20,558
    13,286
    Jul 6, 2009
    You want your ports to put out at least 2.1 amps.
    For a dual device that would be 4.2 amps.
    I"m going on 6 years with my verizon plug. Dual ports.
    I"ve had em break. But never had them fail.
    fargonaz and Suspect Zero Thank this.
  6. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    They aren't high tech. You can get one a 7/11 for $5.
  7. SteveBausch
    128
    55
    Oct 15, 2014
    The cheap ones dispense with the spring-loaded tip, so the power fails the moment the charger isn’t a tight fit in the socket.
    Suspect Zero and Tb0n3 Thank this.
  8. Tb0n3
    Tb0n3 Road Train Member
    4,590
    9,206
    Oct 5, 2012
    Earth
    They also might kill your phone by outputting 12V unregulated, or just barely keep it charged at 500mA. Cheap is not good.
    SteveBausch and Justrucking2 Thank this.
  9. ttypewe4jim
    189
    142
    Feb 21, 2018
    Also some of the cheaper cords out there can cause issues with many of the Lithium Ion newer style batteries. In order to get a good life out of the battery you want a clean consistent power source. Also some of the better chargers can sense when the battery is starting to get full and kick down the power some allowing it to finish charging a lower amp rate reducing the heat output.
  10. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    I second Anker. Get good quality cords too.
    SteveBausch, Justrucking2 and Tb0n3 Thank this.
