Which company for rookie?
Discussion in 'Questions From New Drivers' started by Rocknroller4, Mar 10, 2019.
  1. Rocknroller4
    Rocknroller4 Road Train Member
    1,165
    613
    Nov 25, 2015
    Got the choice between Schneider, May Trucking or Swift. Just curious who you all would go with starting out? With SNI I have to go all the way to Phoenix from the NW but the other two would be trained up here. Not sure who to go with. Going to be on a regional account. Thanks
  3. WesternPlains
    6,298
    53,423
    Sep 1, 2017
    Schneider doesn't allow intelligent life forms in the trucks.
  4. Rocknroller4
    1,165
    613
    Nov 25, 2015
    Have read they are not as good as they used to be.
    Upinsmoke Thanks this.
  5. Texas_hwy_287
    Texas_hwy_287 Road Train Member
    2,097
    2,405
    Sep 25, 2016
    Texas
    Check out roehl, millis, jim palmer or maybe prime:rolleyes:
    Lepton1 Thanks this.
  6. WesternPlains
    6,298
    53,423
    Sep 1, 2017
    You want only regional? 11 Western Only?
    Jim Palmer runs west primarily. Out of Missoula.
    May... Heard lacking in pay. But bought by somebody. Forget who. Based in NW. Interesting?
    Swift or Schneider? Toss a coin?
    Texas_hwy_287 Thanks this.
  7. Upinsmoke
    Upinsmoke Medium Load Member
    612
    1,206
    Feb 26, 2019
    Schneider is fine for a new guy.
    If your going in eventually,choosing your own loads,are the only way to go.
    Expect $1200 a week truck payment,and $1.30 per mile rate.
    Don't do reefer or dollar accounts.
  8. Suspect Zero
    Suspect Zero Road Train Member
    2,511
    9,552
    Oct 10, 2016
    Burbank, IL
    I would recommend Millis as a place to start but if he is from the Northwest he is way out of their area.
  9. Upinsmoke
    612
    1,206
    Feb 26, 2019
    Super singles?
    No thanks!
  10. Suspect Zero
    2,511
    9,552
    Oct 10, 2016
    Burbank, IL
    The 2019s have duels again and but yes, all the 18 and older models are on stupid singles
    Lepton1 and Upinsmoke Thank this.
  11. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    If any newer driver doesn't understand the idiocy of "super singles", let me explain. Super singles are really wide tires, so you don't have "duals" (tires side by side) on each axle.
    What happens if you have a tire blow out with duals? Suddenly you have 1/2 the tires bearing weight on that axle. You have a total of 7 tires bearing the load of what was 8 tires. Not a big deal, right?
    What if you are running super singles and have a tire blow out? Now you have 3 tires supporting the weight that 4 tires should support. On the blown tire side you have half the support.
    Ever been anywhere CLOSE to a tire blowout? Every year truck drivers and truck tire technicians get killed because of explosive failure of truck tires. They go off with the force of a hand grenade. The shrapnel of rubber and sidewall wires can kill a man dozens of feet away.
    I witnessed an unfortunate driver, waiting to get into a TA to replace a super single that had blown out on the rear axle of his dry van. As he was waiting the tire on the axle in front blew out with an explosive force it shattered the windows of the store 100 yards away. Now his trailer had no support on the passenger side. He did well to move forward and get his tractor at more than a 45° angle to the passenger side to prevent a roll over.
    I drove a tractor with super singles starting about four years ago. Absolute idiocy, especially considering that truck had to go off paved roads a significant portion of time. Within the first week I insisted that the owner replace that idiocy with regular duals.
    By the way, don't just put super singles on a truck or trailer that was designed for duals. That puts more stress on the differentials and axles.
