Which engine oil is best for pulling 55 tons gross on a cummins isx?
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Aug 8, 2021.
  1. buzzarddriver
    3,705
    10,940
    Feb 1, 2011
    Dallas, TX
    Talk about a topic making a hard left turn!
    Bean Jr. and Roberts450 Thank this.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Its still hanging on to the original topic even if its only by a thread. Still lube involved. ROFLMAO.
    N00bLaLoosh and Bean Jr. Thank this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,538
    9,875
    Mar 30, 2014
    I don't think that was true. He was married a few times and had quite a few kids. Doesn't prove anything, but...
  5. Bean Jr.
    5,538
    9,875
    Mar 30, 2014
    I couldn't find anything of the sort searching Google.
  6. abyliks
    abyliks Road Train Member
    3,996
    9,394
    May 2, 2010
    ludlow MA
    extended changes are for bean counters, period
    Anyone not wanting to throw their truck away, 15-20k of your choice, I’ve been using mobil delvac, valvoline or rotella are also good choices
    Stray_Dog Thanks this.
  7. Ridgeline
    22,605
    120,056
    I prefer rotella t6 in all the trucks, but delvac extreme is ok, all the trucks get an oil analysis and the fleet average for an oil change is around 32k, way down from the peak because we are doing a lot of local work.
  8. Big Road Skateboard
    6,646
    37,315
    May 2, 2021
    Bean counters? Are you assuming synthetic is junk at 20, or dino is good to 40?
    Synthetic oils do not break down like conventional. Absolute fact that can not be disputed.
    He asked a recommendation and interval, I provided.
    Bean Jr. Thanks this.
  9. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Seeing as he is pulling over 100k cummins will consider that severe duty so should be 20k or less no matter what kinda oil he use’s.
  10. Diesel Dave
    9,235
    29,483
    Jan 20, 2010
    Hesperia, Ca.
    I’m running from a local oil distributor, there 15/40 house Blend, exceeds Guardol XCT specks. Also, I dump a gallon of Wally Worlds SuperTech GL 5 gear oil. This is on a ISX 15.
    Edit;
    Check out R A W Z E(dot)C O M site. He’s a Guru when it comes to ISX engines.
