Which is the best oil?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by fr8wurx, Mar 13, 2013.
  1. fr8wurx
    fr8wurx Light Load Member
    128
    84
    Jan 27, 2013
    Lingle, WY
    I know this is like asking if Ford or Chevy is better. But I am curious as to which oil is better. I have several diesel vehicles all smaller than a semi and have no problems running Rotella in them. They dont see anywhere as many miles as my Freightliner Century. They are lucky to get an oil change once a year. But I am concerned that I may be doing a disservice to my self and my truck by using what is usually the cheapest oil on the market. I have a 2001 Century with a 12.7 Detroit S60. What I am asking is if there is a definite benefit to using one of the higher priced oils. I have been looking in to Lucas Oil but find it hard to fork out the money when it is more than twice the price of what I use now. I know there are a dozen different oils that I can be using, but is there any one that is actually better than the others and by how much?
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Just use a name brand oil (not syn) that is rec for that engine and change oil often, I change my oil every 10,000 to 12,000 miles.
    MM71 and Cowpie1 Thank this.
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Use Mobil Delvac 15W40. I believe its the oil Detroit recommends, plus they rebottle it with their own label. It's also low priced at Wal Mart. This is the same oil I use in my 4 cylinder Saturn. Work's great.
  5. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I have always used Mobil Delvac and changed my oil at 20k-25k miles with samples ALWAYS taken. So far so good and 850k miles
  6. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Aussie Dave is spot on. Just select a name brand oil that is the best value and run it. All the major oils are good. True, that some engines have a slight preference one way or the other regarding a brand, but you will not know that without doing a good oil analysis program and tracking results. You should do that anyway. Very inexpensive to run a sample at each oil change and know what is going on inside that engine. I would just follow the engine manufacturers recommended drain intervals at first. If the oil isn't holding up to that, then back off a little. Your oil sample test will show if it isn't. Most major oils will do fantastic way beyond 15-20000 miles. No use throwing more money down the maintenance hole than you have too.
    To your original point, fr8wurx, I have a 12.7 Series 60 pre-egr that I have excellent oil samples using Delo. Another interesting brand that has shown very good numbers is the Mystik JT-8 engine oil. It is usually sold at Farm and Home type of stores. That is a sleeper of an oil, in that it rivals the quality of the normal name brands and can be had, usually, much cheaper. Same can be said of the Kendall engine oils. I took a Cummins N-14 to 1.4 million on Kendall oil doing 30,000 mile oil changes and never had an engine problem.
    This is why I state, find a good oil at the best value you can. And follow good maintenance procedures. There is NO one best oil. The only thing one could possibly do in regard to what you are doing is maybe the type of oil filters you get and maybe using a bypass or centrifuge for additional filtration. That would do more for you than any one brand of oil, as keeping the oil cleaner will do more to protect your engine than some boutique engine oil. I like the results from Donaldson Extended Life oil filters on my Series 60. I am also using a bypass filter. Oil samples come out really good. At the shop I frequent for my oil changes, the Donaldson Extended Life are the same price as the regular Donaldsons. No brainer. Yet the extended life version offers a synthetic matrix filter media compared to paper. It will filter finer than the standard version filter yet offers a slightly better flow rate. Good value in a filter.
    Mcast3092 and fr8wurx Thank this.
  7. fr8wurx
    128
    84
    Jan 27, 2013
    Lingle, WY
    Thank you Cowpie1, that is a well thought out and informative answer. I appreciate any help that I can get.
  8. Mcast3092
    Mcast3092 Light Load Member
    137
    107
    Jul 31, 2018
    Why not syn?
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    I have used Rotella T all of my trucking life. Just be sure the weight and SAE fits what the engine requires.
    Ive carried enough gallons to endure a loss of several gallons if the oil cap blew off or something else leaked too much as happened a couple of times. Pricing is of no concern. Its a bottle of gallon Rotella. Dump it in there. The higher level thinking goes to the shop people. I am just a "Drivah"
    Mcast3092 Thanks this.
  10. Mcast3092
    137
    107
    Jul 31, 2018
    Haha thank you sir, I’m using delo 15w40 synblend it’s about $16-17 at Walmart.
  11. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    Check out Schaefer. They claim a high detergency package in their oil that will clean up a dirty motor. I’m running the Ultra Performance 10w30 right now and in 60k miles I’ll see inside when I do my overhead. Most engine oils are great these days. The only real difference is how powerful is the detergency. Schaefer, Royal Purple, Delo, Valvoline Premium Blue, and Total are the oils that I feel have the highest detergency. It’s hard to gather that from their data sheets. I go by oil samples I’ve seen posted and there are YouTube videos out there as well.
    Delo has a new oil coming out this month called Delo 600. I’d lie to check that one out..
