Which oil do you think is the best among these two.
Discussion in 'Ask An Owner Operator' started by Ikamob01, May 6, 2023.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Which oil do you think is the best among these two. Or please tell us your recommendation. see pics below.
  3. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Winter versus summer formulations
    Rideandrepair, Numb and gokiddogo Thank this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    They're both 40 weight oils the 5w or 15w just refers to the temp it will flow at for a cold start. 5w cost more than 15w. They also make 0w40. When it gets that cold people usually idle it anyway or plug it in at home or have coolant heaters, etc.
    Just get the 15w40
  5. Short Fuse EOD
    2,778
    8,684
    Jul 29, 2015
    Midwest
    My preference. I us the chevron XSP 5w-40.
    Before at 15W-40 XLE I’d idle when it got under 11 degrees. With the XSP 5W-40 I idle around 2 degrees. Again, those are my preferences. I save on fuel by not idling at night enough to make the cost difference up for the year. I run the same oil in my X15 and Carriers.
    Rideandrepair and Ikamob01 Thank this.
  6. Lazer
    Lazer Road Train Member
    1,803
    2,879
    Jan 22, 2017
    As others have stated, depending on the weather you predominantly operate in. Myself, I’d go with the 15w40. Granted I am in the Permian Basin of Texas, as ‘winter’ is relative term.
    But as company driver, I put in the engine what am told. If I was ‘director of maintenance’ in our frac fleet( pumps, blenders, etc) that run for days on end, and may not be shut down for any length of time but for quick p.m., I’d authorize a straight 30w diesel motor oil.
    Rideandrepair, JoeyJunk and Ikamob01 Thank this.
  7. Mnmover99
    Mnmover99 Light Load Member
    248
    343
    Oct 22, 2022
    The DA Lubricant oil is better because it has more Zinc in the formulation
    Rideandrepair Thanks this.
  8. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    Both good.
    There are temperature range charts in truck/engine manuals with recommended oil viscosity for your operating environment.
  9. Rideandrepair
    17,357
    56,317
    Aug 8, 2015
    Should be a recommended oil sticker on valve cover. Brand is preference, but viscosity is usually listed also. T6 is for newer engines.
  10. Ikamob01
    314
    195
    Dec 4, 2021
    Actually, Y6 is for older engines. But I guess what you are saying tho.
  11. skallagrime
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Define old? And no, not really
    T6 is full synthetic
    T5 is semi synthetic
    T4 is non synth
    They all meet ck-4 api standards, which are backwards compatible to cj-4
    As a rule of thumb, any current rated oil (as long as viscosity is correct) will work in older engines, BUT synthetics and semi-synthetics do tend to exacerbate any oil leak/consumption you already have with the refined oil.
    i.e. older engines leak more with t6 than t4
    Siinman and gokiddogo Thank this.
