Which post do I install an amplifier on?
Discussion in 'Questions From New Drivers' started by JoeF2002, May 17, 2016.
  1. JoeF2002
    JoeF2002 Light Load Member
    165
    119
    Dec 31, 2015
    Saylorsburg, PA
    Hey gang - I have a 12V amplifier I'd like to install on the truck. I've done it before on cars, but not a big rig. I know this may sound like a stupid question, but for the power line, which battery terminal post (below) should I connect to? I believe either of the two front + lines will work. But I want to be sure before hooking up anything. Appreciate the help!
  3. Stachegravy
    Stachegravy Bobtail Member
    19
    29
    May 17, 2016
    Utah
    Check google on "12 v batteries wired in series or parallel" for this kind of knowledge. None of us wants to get you hurt by a misunderstanding of ideas. Good luck
  4. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    Truck batteries are not wired in series, they are in parallel so that they still give just 12 volts to the trucks electrical system. The extra batteries just add more available amps.
    Even if they were in series every individual battery is still 12 volts so you could just hook up to the positive and negative of the same battery and get 12 volts.
    If you are grounding the amp to the frame somewhere you can use any of the positive posts and be fine, just be sure to have a fuse in line close to the battery in case of a short in the wire or a fault in the amp.
    Stachegravy Thanks this.
  5. Moose1958
    Moose1958 Road Train Member
    15,169
    33,410
    Dec 17, 2010
    Williesburg, Virignia
    To the best of my knowledge all electrical systems on trucks is 12 volts. It would be a huge help if more people understood the difference between a battery and a cell.
  6. JoeF2002
    165
    119
    Dec 31, 2015
    Saylorsburg, PA
    Appreciate the advice everyone. So it sounds like any of the 12V+ posts will work for the amp connection. Thanks a million!
