Which set would be best for getting out farther?
Discussion in 'CB Radio Forum' started by rainmakerr, Jan 28, 2014.
  1. rainmakerr
    rainmakerr Light Load Member
    100
    25
    Mar 15, 2012
    Centreville, AL
    I drive a 2012 Cascadia and was wondering which antenna would be best for "getting out". I have a Galaxy 29 and ran my own coax to a Wilson 2000, was only able to get the SWR down to 1:5-1:6 with an external meter. I put a Firestik II and got my SWR down to 1:3, shouldn't the Firestik II give me further distance than the Wilson?
  3. MsJamie
    MsJamie Road Train Member
    If the best you can do is a 3:1 SWR, then there is something wrong with your antenna installation. Most likely the problem is a poor ground at the antenna.
    As for performance, the rule of thumb is the bigger the antenna, the bigger the signal.
  4. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    Where do you see 3:1? it says 1:3
    poppapump1332 Thanks this.
  5. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    -"dyslexic"-:dontknow::biggrin:
  6. cuzzin it
    cuzzin it Road Train Member
    3,625
    10,829
    Jan 19, 2008
    Berea, KY
    Algebra claims another victim. first is left equals right the they keep whating you to know Y...... and next thing you know, 1.3 becomes 3 to 1
    mike5511 and Razor3 Thank this.
  7. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    Even I know that a 3:1 is horrible, oh well.
  8. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    You ask about a "set" (I assume you mean pair?) but, say you ran "a" coax to a wilson/firestik. <--- the coax is different 50 ohm vs. 75 ohm.
    Running your own I'd suggest a single ant. w/ RG8x
    The best antenna is the one that can survive your abuse, while making it as long and tall as possible. <--- I'm no ham, but this is what I was taught.
    The fiberglass whip is great for top load making it more desirable, however tree limbs will quickly muck it up.
    The loaded ant's like wilson2k don't get the "load" as high, but it is good around low clearance's for the abuse it will take.
    Big_m Thanks this.
  9. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    OK, what I am saying is that I ran my own coax in the truck instead of using what came in the truck, running only one antenna on the driver's side. The above mentioned results were from the different antennas on the coax that I installed. Once I had the Wilson tuned it was only about an inch higher than the Firestik II. The Firstik does not hit on anything under normal circumstances (It may hit on a low hanging limb at one of my drops but I usually am able to keep it from hitting the antenna)
  10. TheDude1969
    807
    823
    Jun 10, 2013
    Joliet, Il
    In theory, yes the firestik should get you out further for its top loaded design.
  11. Ridgeline
    22,526
    119,040
    No it won't make a lot of difference when you come down to it.
    What does is a lack of signals on the channel.
