While do diesel 4-wheelers always idle their pickups??
Discussion in 'Experienced Truckers' Advice' started by Harry Flashman, Feb 25, 2025.
  1. Harry Flashman
    Harry Flashman Medium Load Member
    510
    1,359
    Oct 4, 2019
    Honest question, I have never owned a diesel pickup and I’m genuinely curious about this.
    I see this all the time at truckstops, gas stations, and elsewhere. Some guy pulls up in his diesel pickup and idles his truck while he goes inside, and there is nobody else inside his truck.
    I understand why semis idle (AC, power), however it has never made sense to me why these pickup 4-wheelers idle. You never see this same behavior with gas vehicles or gas pickups.
    Just ranting here because someone pulled up next to me in a very noisy diesel pickup (no trailer either) He left his truck idling for over an hour while he wasn’t inside. Fair weather 60 degrees, it’s not cold. I’m thinking to myself why do I have to listen to this crap? What purpose is this serving?
  3. Kyle G.
    Kyle G. Road Train Member
    3,878
    20,401
    Jan 23, 2016
    Eastern Iowa
    They are pretending to be super truckers
  4. Grumppy
    3,103
    10,685
    Dec 11, 2010
    West Monroe, La
    Some people just gotta do things... no reason really.
    okiedokie, Lonesome, Oxbow and 5 others Thank this.
  5. Arctic_fox
    4,146
    21,536
    Sep 16, 2016
    I do this occasionally when im home. Mostly because my truck sits for 6-12 weeks at a time and it gives it a chance to deep charge the batterys that tend to get low after so much time. Especially in winter. But i never leave it unattended for longer then running inside to pay for fuel or something. Or while im chowing down in the cab.
    Otherwise no clue.
    unloader, Oxbow, OldeSkool and 3 others Thank this.
  6. Ridgeline
    22,449
    117,307
    Well some are not too bright - just look ...
    I've got one near me with 7-inch stacks on a second-generation dodge cummins, it is a real mess.
    Maybe ... or maybe not ... it could be trying to compensate for manly parts being ... small ...??
    Get this one ...
  7. Texasgordo
    Texasgordo Medium Load Member
    398
    1,157
    Sep 11, 2007
    Gonzales, Texas
    I've had a diesel pickup truck for about 20 years now in south central Texas and never leave it idling even in summer. I really don't see a reason to leave it idling if I'm not sitting inside.
  8. Accidental Trucker
    Accidental Trucker Road Train Member
    3,364
    7,391
    Jun 4, 2015
    There’s an old myth out there that it’s better to idle a diesel than to shut off and start.
    like WAY before DPF.
  9. OldeSkool
    OldeSkool Road Train Member
    1,747
    5,063
    Jul 17, 2018
    New Hampshire
    The same reason they like to fill up at the truck diesel pumps instead of the ones where the four wheelers are supposed to. It makes them feel good.
  10. Razororange
    Razororange Road Train Member
    2,516
    24,051
    Dec 20, 2011
    Milwaukee, WI
    Except for the part where I use an EFS fuel card even for my personal truck. The car side diesel pumps don't take EFS cards so I have to use the truck pumps.
    As for extended idling, I'll leave it running during the winter for heat especially when it's near 0. I'd rather spend a few bucks on fuel over dealing with gelled fuel lines. Diesel pickup engines also take significantly longer to heat up than gas. Longer engine heat up times also means longer until heat blows inside.
  11. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,947
    3,313
    Jun 10, 2019
    I have a 7.3 and sometimes she can be finicky to start. Once it's running, I leave it running until I HAVE to shut it off. I won't leave it running for an hour, but if I park to put fuel in it, or grab something from a fast food joint, if I don't go through the drive through, I'll just leave it idling. It doesn't burn enough to hurt anything and its a non-DPF truck anyway.
