Hey cb guys,
I like to think that I'm not ignorant of many things, but when I am, I ask.
So here's the equipment:
Cobra 29 (stock, no tune)
Firestik 2 4' (because I can't find a 5')
K40 mount
Wilson spring
Wilson mirror mount perch
18' K40 coax
External visor clip speaker
Mounted on company cascadia passenger side through the door
Swrs 1.5 across the bands (external meter)
Range at least 2-3 miles, clear transmit.
Issue:
With rf gain all the way up sometimes i get a persistent high pitched whistle that isn't very loud but is annoying. I was wondering if this is a symptom of a problem or if it is normal to accompany the regular static.
Also wanted to know if there is a way to tune the radio to reduce the static and pick up the faint voices better.
Thanks in advance.
Whistling receive
Discussion in 'CB Radio Forum' started by QuietStorm, Aug 22, 2017.
Page 1 of 5
A video of the radio doing this would help.
rabbiporkchop, Blaskowitz and QuietStorm Thank this. -
Any theories or potential reasons why it would do that until then? -
These new trucks are full of electronic noise makers. It's hard to say. Computers, injectors etc. Even these cheap cigarette lighter USB chargers can make noise.
BTShepp, Blaskowitz and QuietStorm Thank this. -
What about tuning it to reduce the static noise but also gaining clarity on actual transmissions on the band, is that possible? -
Are you hearing this noise on receive, or are others hearing it mixed with your transmission?
Your mission until you can get a video of it is to unplug all your stuff one by one. GPS, cellphone etc. Maybe you will get lucky and it will be something simple.
QuietStorm Thanks this. -
Blaskowitz Thanks this.
Page 1 of 5
