white smoke ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by idgaf27, Nov 17, 2009.
  1. idgaf27
    idgaf27 Bobtail Member
    5
    NJ
    I am new here, so quick introduction:
    Name is KG
    I am a carhauler
    2001 Sterling with ISM350 , 10sp Rockwell this is most reecent addition. Issue I have with it, and like you to chip in, is - WHITE SMOKE out of exaust. Mechanic called me and said "white smoke comes out of exzaust" . I did not see a problem with that 'cause it is NOT loosing coolant.
    Mechanic sais oil gets into turbo. SHOULDN'T SMOKE BE BLACK in that case?
    Wondering if he ( mechanic) trying to screw me.
    Truck is in San Diego, CA. ~800k miles on a clock.
  3. 69W900A
    69W900A Bobtail Member
    37
    5
    Nov 2, 2009
    This side of No Where
    White smoke can be several things. Coolant is a possibilty. Unburnt fuel is the most common cause along with a turbo pushing oil out of the turbine side.
    Black smoke will be partially unburnt fuel.
    Unless you have modified the engine it should not smoke hardly at all. A 350 will get just a puff of black on a hard upshift and should run clean under load. You shouldn't ever get any white smoke unless it's a cold start in pretty cool weather and that should clear up within a few minuets.
    When does it smoke white? All the time, at startup, under load, etc.?
  4. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    Have you changed fuel filters? 1st thing I would do.
