Who fills the secondary fuel filter on CAT engines when changing filter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CountryBumkin, Aug 22, 2019.
  1. CountryBumkin
    CountryBumkin Bobtail Member
    43
    39
    Jun 4, 2018
    CAT does not recommend filling the secondary fuel filter when changing that filter. They want it installed dry. Reason is that they are concerned about getting dirt into the fuel system.
    However installing the filter dry can cause loss of prime and failure to start. Also on the HEUI systems, getting air into the fuel system can damage the injectors - and an empty filter introduces air into the fuel system.
    So I always fill (fill from the outside holes so any dirt that may get in is trapped by filter media).
    What do you guy do? Fill or not fill?
    Oxbow Thanks this.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    I will either fill it from a freshly opened bottle of Howes (if I'm in a hurry), or leave it dry, crack the return line open and crank it until it starts, 30 seconds at a time with a couple minutes cool down.
    I never let any oil change place do the secondary filter.
    Oxbow Thanks this.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    I use those paper screen funnels they use for paint to fill mine. Or get a plastic funnel from parts store that has a screen in them.
    Oxbow Thanks this.
  5. CountryBumkin
    43
    39
    Jun 4, 2018
    I'm an old retired truck mechanic (not a lot of CAT experience) but never heard of leaving the secondary fuel filter dry on any engine. But maybe these newer motors with electronic fuel injectors it's now recommend installing dry to keep dirt of out fuel system.
    Is this a CAT thing - or does Detroit and Cummins now want fuel filters installed dry too?
  6. AModelCat
    161,299
    I've said my piece on a thread like this a few weeks ago and got flamed bad for it. So do what you want, its your truck.
    Oxbow and spyder7723 Thank this.
  7. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I've been filling fuel filters full clean diesel before installing for 30 years and have never had a problem doing it that way. Never.
    Having said that. Cat does recomend not too.
    Oxbow, Muddydog79, Diesel Dave and 2 others Thank this.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    If you look on the Cat filters right on the side is a diagram of what you do, pour fuel in the filter, put filter on, you'll be cursing for an hour if you try to put dry filters on a Cat.
    Diesel Dave and Art Vandelay Thank this.
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    They recomend spinning dry filter on the engine then priming it with the hand primer to fill the filter. Takes way to long and is a pain in the ###
  10. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Also gives you a nice blister on your hand.
  11. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I use the howes and have never had a problem.
    Oxbow Thanks this.
  12. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    Not all of us have hand primers. I always fill mine. I have even chunked a new filter after I filled it cause I didn’t trust the fuel I used was clean. Chunk it and get another
    Oxbow Thanks this.
