Why am I supposed to press the clutch all the way to the floor before I do a regen?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by expedite_it, Nov 15, 2015.
  1. expedite_it
    expedite_it Road Train Member
    1,646
    864
    Sep 8, 2012
    At the company I work for, they give us a piece of paper with instruction for how to do a regen. Before we do a regen on our trucks, we are supposed to push the clutch pedal all the way to the floor and then let it back out again. Also, before we do a regen, we are supposed to push the brake valves in and then pull them back out again. Then we press the regen button to do a regen.
    What is the purpose of pushing the clutch pedal all the way to the floor and then letting it back out again before we do a regen?
    What is the purpose of pushing the brake valves in and then pulling them back out against before we do a regen?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    Hmmm. I find on my DD15 I only have to push on the clutch enough for the switch to activate, so something close to a normal push.
    All the other stuff is just to make sure that you know, and the esm knows that the truck is in neutral, parked, parking brake set and ready to do it's thing.
    I have the ECM Auto Elevate parameter set, so if the truck is already parked on fast idle, it will just automatically do a parked regen on it's own accord without any input from me. I don't normally idle the truck overnight, except when it's below -30. So if at 4:00 am it decides it needs a regen, it just goes ahead and does one instead of setting off alarms, making me get out of bed.
  4. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    That seems unnecessary to me. I think they are trying to avoid a sticky pedal from inhibiting a regen and making sure it is up all the way.
    bad attitude 75 Thanks this.
  5. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Yeah, that's what I'm thinking, although all the regens I've done were on Cummins and PACCAR engines, and those were all forced regens (with the engine software). I don't necessarily know the parked regen procedures for all engine makes if they vary significantly.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    These are the steps that are in the manual for my DD16
    1. Keep engine at slow idle (cannot be in PTO mode).
    2.Cycle transmission out of neutral and back into neutral.*
    3. Cycle the park brake from OFF to ON.*
    4. Press and release clutch pedal.*
    5. Hold DPF Switch to the ON position for five seconds, then release. Engine speed will increase and DPF Lamp will go out.
    *These steps are not required on GHG14 engines or later.
    I'm glad that I dont have to do steps 2 thru 4.
    I'm going to stop at a Detroit shop and have that turned on, it sucks getting woke up in the morning with the Regen alarm going off.
    mhyn and TruckDuo Thank this.
  7. Star4900
    Star4900 Medium Load Member
    607
    521
    Mar 16, 2015
    Northern Ontario
    I don't do any of that on my Cummins or Detroit. As long as it is idling with the parking brake on, just push the regen switch and away it goes.
  8. Star4900
    607
    521
    Mar 16, 2015
    Northern Ontario
    When I have to start doing all those steps, here will be my regen procedure.......fill 5 gallon can with gas. Slide under truck. Insert rag in opening of can. Light rag on fire with lighter, then go for a long walk.
    Cat sdp and W900AOwner Thank this.
  9. W900AOwner
    W900AOwner Heavy Load Member
    714
    1,284
    Jul 2, 2014
    Where is the regen switch located in my 1978 Kenworth W900A?
  10. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Pushing the clutch all the way to the floor activates the clutch brake which stops the transmission from turning. Not sure what that has to do with a regen but that's what happens.
  11. W900AOwner
    714
    1,284
    Jul 2, 2014
    Most likely because the ECM senses the clutch/input shaft is still rotating until it is manually stopped...
